XLINK Map File for "D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Exe\enc28j60_s"
IAR Universal Linker V5.3.2.26
Copyright (C) 1987-2012 IAR Systems AB.
Invocation   Program Entry   Module Map   Segment Map   Memory Summary
Link time 16/Jul/2013 20:41:06
Target CPU MSP430
List file D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\List\enc28j60_s.html
Output file 1 D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Exe\enc28j60_s.d43
Format: debug
UBROF version 10.0.6
Using library modules for C-SPY (-rt)
Command line D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\enc28j60.r43 D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\ip_arp_udp_tcp.r43 D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\main.r43 D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\spi.r43 D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\web.r43 -o D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Exe\enc28j60_s.d43 -l D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\List\enc28j60_s.html -xmsh -p80 "-"C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4 Evaluation\430\LIB\" -f "C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4 Evaluation\430\CONFIG\lnk430G2553.xcl" ( -cmsp430 -QCODE_I=CODE_ID -Z(DATA)DATA16_I,DATA16_Z,DATA16_N,TLS16_I,DATA16_HEAP+_DATA16_HEAP_SIZE=0200-03FF -Z(DATA)CODE_I -Z(DATA)CSTACK+_STACK_SIZE# -Z(CONST)INFO=1000-10FF -Z(CONST)INFOA=10C0-10FF -Z(CONST)INFOB=1080-10BF -Z(CONST)INFOC=1040-107F -Z(CONST)INFOD=1000-103F -Z(CONST)DATA16_C,DATA16_ID,TLS16_ID,DIFUNCT,CHECKSUM=C000-FFDF -Z(CODE)CSTART,ISR_CODE,CODE_ID=C000-FFDF -P(CODE)CODE=C000-FFDF -Z(CODE)INTVEC=FFE0-FFFF -Z(CODE)RESET=FFFE-FFFF ) -D_STACK_SIZE=50 -rt "C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4 Evaluation\430\LIB\DLIB\dl430fn.r43" -e_PrintfLarge=_Printf -e_ScanfLarge=_Scanf -D_DATA16_HEAP_SIZE=50 -s __program_start -D_DATA20_HEAP_SIZE=50
- Cross-reference - Page 1
Program entry at : C246 Relocatable, from module : ?cstart
Runtime Model
Attribute Value
__Heap_Handler Basic
__SystemLibrary DLib
__core 430
__dlib_file_descriptor 0
__dlib_full_locale_support 0
__double_size 32
__pic no
__reg_r4 free
__reg_r5 free
__rt_version 3
Automatic Symbol Redirections
There are no automatic symbol redirections.
Module Map
File Module Segment Symbol Address Ref by
?ABS_ENTRY_MOD
Program module
Absolute parts _DATA20_HEAP_SIZE 0050 -
_DATA16_HEAP_SIZE 0050 -
_STACK_SIZE 0050 -
D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\enc28j60.r43 enc28j60
Program module
DATA16_AN
Relative segment
0029 - 0029
Segment part 1. ROOT.
Intra module refs   SPI_init (spi)
enc28j60ReadBuffer
enc28j60ReadOp
enc28j60WriteBuffer
enc28j60WriteOp
P2OUT 0029 -
DATA16_Z
Relative segment
0212 - 0212
Segment part 3.
Intra module refs   enc28j60SetBank
Enc28j60Bank 0212
DATA16_Z
Relative segment
0208 - 0209
Segment part 4.
Intra module refs   enc28j60Init
enc28j60PacketReceive
NextPacketPtr 0208
<CODE> 1
Relative segment
D240 - D277
Segment part 7.
Intra module refs   enc28j60PacketReceive
enc28j60Read
enc28j60ReadOp
calls direct
CSTACK = 00000000 ( 00000006 )
D240 -
<CODE> 1
Relative segment
D492 - D4B1
Segment part 5.
enc28j60PacketSend
enc28j60SetBank
enc28j60Write
enc28j60WriteOp
calls direct
CSTACK = 00000000 ( 00000004 )
D492 -
<CODE> 1
Relative segment
D278 - D2AD
Segment part 6.
enc28j60ReadBuffer
calls direct
D278 -
<CODE> 1
Relative segment
D3AC - D3D9
Segment part 12.
Intra module refs   enc28j60PacketSend
enc28j60WriteBuffer
calls direct
D3AC -
<CODE> 1
Relative segment
D0AE - D0F7
Segment part 8.
enc28j60Read
enc28j60Write
enc28j60SetBank
calls direct
D0AE -
<CODE> 1
Relative segment
D508 - D51D
Segment part 10.
enc28j60PacketSend
enc28j60PhyWrite
enc28j60Read
calls direct
D508 -
<CODE> 1
Relative segment
D472 - D491
Segment part 9.
enc28j60PacketSend
enc28j60PhyWrite
enc28j60clkout
enc28j60Write
calls direct
D472 -
<CODE> 1
Relative segment
D012 - D061
Segment part 15.
enc28j60PhyWrite
calls direct
D012 Web_setup (web)
<CODE> 1
Relative segment
D5BC - D5C9
Segment part 17.
enc28j60clkout
calls direct
CSTACK = 00000000 ( 00000002 )
D5BC Web_setup (web)
<CODE> 1
Relative segment
C26E - C415
Segment part 16.
enc28j60Init
calls direct
C26E main (main)
<CODE> 1
Relative segment
CD68 - CDEB
Segment part 13.
enc28j60PacketSend
calls direct
CD68 make_arp_answer_from_request (ip_arp_udp_tcp)
make_echo_reply_from_request (ip_arp_udp_tcp)
make_tcp_ack_from_any (ip_arp_udp_tcp)
make_tcp_ack_with_data (ip_arp_udp_tcp)
make_tcp_synack_from_syn (ip_arp_udp_tcp)
<CODE> 1
Relative segment
C9FE - CAE1
Segment part 11.
calls direct
CSTACK = 00000000 ( 0000000A )
C9FE Web_serviceRequest (web)
D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\ip_arp_udp_tcp.r43 ip_arp_udp_tcp
Program module
DATA16_I
Relative segment
0202 - 0202
Segment part 2.
Intra module refs   init_ip_arp_udp_tcp
make_tcphead
wwwport 0202
DATA16_Z
Relative segment
0213 - 0218
Segment part 4.
make_eth
macaddr 0213
DATA16_Z
Relative segment
0219 - 021C
Segment part 5.
Intra module refs   eth_type_is_arp_and_my_ip
eth_type_is_ip_and_my_ip
init_ip_arp_udp_tcp
make_ip
ipaddr 0219
DATA16_Z
Relative segment
020A - 020B
Segment part 6.
Intra module refs   get_tcp_data_pointer
init_len_info
info_hdr_len 020A
DATA16_Z
Relative segment
020C - 020D
Segment part 7.
init_len_info
info_data_len 020C
DATA16_I
Relative segment
0203 - 0203
Segment part 8.
Intra module refs   make_tcphead
seqnum 0203
<CODE> 1
Relative segment
CBAC - CC4D
Segment part 13.
Intra module refs   fill_ip_hdr_checksum
checksum
CSTACK = 00000000 ( 00000008 )
CBAC -
<CODE> 1
Relative segment
D2E4 - D317
Segment part 35.
init_ip_arp_udp_tcp
D2E4 main (main)
<CODE> 1
Relative segment
D204 - D23F
Segment part 34.
D204 Web_serviceRequest (web)
<CODE> 1
Relative segment
D140 - D185
Segment part 33.
D140 Web_serviceRequest (web)
<CODE> 1
Relative segment
D3DA - D407
Segment part 23.
Intra module refs   make_arp_answer_from_request
make_eth
D3DA -
<CODE> 1
Relative segment
D186 - D1C5
Segment part 14.
Intra module refs   make_ip
calls direct
D186 -
<CODE> 1
Relative segment
D37E - D3AB
Segment part 21.
Intra module refs   make_echo_reply_from_request
make_ip
calls direct
D37E -
<CODE> 1
Relative segment
CAE2 - CBAB
Segment part 22.
Intra module refs   make_tcp_ack_from_any
make_tcphead
CAE2 -
<CODE> 1
Relative segment
CDEC - CE65
Segment part 32.
calls direct
CDEC Web_serviceRequest (web)
<CODE> 1
Relative segment
D2AE - D2E3
Segment part 31.
calls direct
D2AE Web_serviceRequest (web)
<CODE> 1
Relative segment
CFB8 - D011
Segment part 29.
calls direct
CFB8 Web_serviceRequest (web)
<CODE> 1
Relative segment
D55E - D571
Segment part 28.
D55E Web_serviceRequest (web)
<CODE> 1
Relative segment
D0F8 - D13F
Segment part 27.
init_len_info
D0F8 Web_serviceRequest (web)
<CODE> 1
Relative segment
D4EC - D507
Segment part 26.
fill_tcp_data_p
D4EC Web_serviceRequest (web)
<CODE> 1
Relative segment
CE66 - CEDF
Segment part 24.
calls direct
CE66 Web_respond (web)
<CODE> 1
Relative segment
CF52 - CFB7
Segment part 20.
calls direct
CF52 Web_respond (web)
DATA16_ID
Relative segment
C240 - C240
Segment part 3.
Intra module refs   wwwport
DATA16_ID
Relative segment
C241 - C241
Segment part 9.
Intra module refs   seqnum
D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\main.r43 main
Program module
DATA16_AN
Relative segment
01B0 - 01B1
Intra module refs   ADC_conv
ADC10CTL0 01B0 -
DATA16_AN
Relative segment
01B2 - 01B3
Segment part 2. ROOT.
ADC10CTL1 01B2 -
DATA16_AN
Relative segment
01B4 - 01B5
Segment part 3. ROOT.
ADC10MEM 01B4 -
DATA16_AN
Relative segment
0056 - 0056
Segment part 4. ROOT.
Intra module refs   main
DCOCTL 0056 -
DATA16_AN
Relative segment
0057 - 0057
Segment part 5. ROOT.
BCSCTL1 0057 -
DATA16_AN
Relative segment
0021 - 0021
Segment part 6. ROOT.
P1OUT 0021 -
DATA16_AN
Relative segment
0022 - 0022
Segment part 7. ROOT.
main
P1DIR 0022 -
DATA16_AN
Relative segment
0120 - 0121
Segment part 8. ROOT.
WDTCTL 0120 -
DATA16_AN
Relative segment
10FC - 10FC
Segment part 9. ROOT.
CALDCO_8MHZ 10FC -
DATA16_AN
Relative segment
10FD - 10FD
Segment part 10. ROOT.
CALBC1_8MHZ 10FD -
DATA16_C
Relative segment
C000 - C03D
Segment part 12.
DATA16_C
Relative segment
C03E - C04A
Segment part 13.
DATA16_C
Relative segment
C04B - C073
Segment part 14.
DATA16_C
Relative segment
C074 - C08E
Segment part 15.
DATA16_C
Relative segment
C08F - C0AB
Segment part 16.
DATA16_C
Relative segment
C0AC - C0D9
Segment part 17.
DATA16_C
Relative segment
C0DA - C115
Segment part 18.
DATA16_C
Relative segment
C116 - C122
Segment part 19.
DATA16_C
Relative segment
C123 - C15B
Segment part 20.
DATA16_C
Relative segment
C15C - C15F
Segment part 21.
DATA16_C
Relative segment
C160 - C164
Segment part 22.
DATA16_C
Relative segment
C165 - C173
Segment part 23.
DATA16_C
Relative segment
C174 - C179
Segment part 24.
mac C174 -
DATA16_I
Relative segment
0204 - 0207
Segment part 25.
ip 0204 -
DATA16_I
Relative segment
0200 - 0201
Segment part 27.
port 0200 -
DATA16_Z
Relative segment
020E - 020F
Segment part 29.
data 020E -
<CODE> 1
Relative segment
D450 - D471
Segment part 31.
ADC_conv
D450 -
<CODE> 1
Relative segment
C906 - C9FD
Segment part 32.
main
calls direct
C906 Segment part 17 (?cstart)
DATA16_ID
Relative segment
C242 - C245
Segment part 26.
Intra module refs   ip
DATA16_ID
Relative segment
C23E - C23F
Segment part 28.
Intra module refs   port
D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\spi.r43 spi
Program module
DATA16_AN
Relative segment
0003 - 0003
Intra module refs   SPI_transfer
IFG2 0003 -
DATA16_AN
Relative segment
0026 - 0026
P1SEL 0026 -
DATA16_AN
Relative segment
0041 - 0041
P1SEL2 0041 -
DATA16_AN
Relative segment
002A - 002A
P2DIR 002A -
DATA16_AN
Relative segment
0068 - 0068
UCB0CTL0 0068 -
DATA16_AN
Relative segment
0069 - 0069
UCB0CTL1 0069 -
DATA16_AN
Relative segment
006A - 006A
UCB0BR0 006A -
DATA16_AN
Relative segment
006B - 006B
UCB0BR1 006B -
DATA16_AN
Relative segment
006E - 006E
Segment part 11. ROOT.
UCB0RXBUF 006E -
DATA16_AN
Relative segment
006F - 006F
Segment part 12. ROOT.
UCB0TXBUF 006F -
<CODE> 1
Relative segment
D1C6 - D203
Segment part 15.
SPI_init
D1C6 enc28j60Init (enc28j60)
<CODE> 1
Relative segment
D534 - D549
Segment part 14.
SPI_transfer
D534 enc28j60ReadBuffer (enc28j60)
enc28j60ReadOp (enc28j60)
enc28j60WriteBuffer (enc28j60)
enc28j60WriteOp (enc28j60)
D:\Msp430_and_all_Msp\Projektek\MSP430G2553\ENC28j60_s\Debug\Obj\web.r43 web
Program module
DATA16_Z
Relative segment
021D - 037B
Segment part 8.
Intra module refs   Web_print
Web_respond
Web_serviceRequest
buf 021D -
DATA16_Z
Relative segment
037C - 039C
Segment part 9.
Intra module refs   Web_serviceRequest
strbuf 037C -
DATA16_Z
Relative segment
0210 - 0211
Segment part 10.
Web_respond
Web_serviceRequest
plen 0210 -
<CODE> 1
Relative segment
CEE0 - CF51
Segment part 17.
Web_setup
calls direct
CEE0 main (main)
<CODE> 1
Relative segment
C578 - C6C5
Segment part 16.
Web_serviceRequest
calls direct
C578 main (main)
<CODE> 1
Relative segment
D42E - D44F
Segment part 14.
Intra module refs   Web_print_num
Web_print
D42E main (main)
<CODE> 1
Relative segment
D4B2 - D4CF
Segment part 15.
Web_print_num
calls direct
CSTACK = 00000000 ( 0000000C )
D4B2 main (main)
<CODE> 1
Relative segment
D572 - D585
Segment part 13.
Web_respond
calls direct
D572 main (main)
<CODE> 1
Relative segment
CCE0 - CD67
Segment part 12.
itoa
CSTACK = 00000000 ( 00000010 )
CCE0 -
<CODE> 1
Relative segment
D54A - D55D
Segment part 11.
Intra module refs   Web_setup
delay_ms
D54A enc28j60Init (enc28j60)
DATA16_C
Relative segment
C17A - C17E
Segment part 2.
DATA16_C
Relative segment
C17F - C1BA
Segment part 3.
DATA16_C
Relative segment
C1BB - C1C5
Segment part 4.
DATA16_C
Relative segment
C1C6 - C1C7
Segment part 5.
DATA16_C
Relative segment
C1C8 - C1F4
Segment part 6.
DATA16_C
Relative segment
C1F5 - C23C
Segment part 7.
Intra module refs   itoa
C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.4 Evaluation\430\LIB\DLIB\dl430fn.r43 ?__dbg_break
Library module
<CODE> 1
Relative segment
D5E2 - D5E3
Segment part 2.
__DebugBreak D5E2 __exit (?__exit)
?__exit
Library module
<CODE> 1
Relative segment
D51E - D533
Segment part 2.
__exit
calls direct
D51E Segment part 6 (?_exit)
_exit (?_exit)
?_exit
Library module
<CODE> 1
Relative segment
D5D6
Segment part 0.
_exit D5D6 exit (?exit)
<CODE> 1
Relative segment
D5D6 - D5D9
Segment part 6.
Intra module refs   _exit
?cstart
Library module
CSTACK
Relative segment
03B0
Segment part 1.
DATA16_Z
Relative segment
0212
Segment part 2.
DATA16_I
Relative segment
0202
Segment part 3.
DATA16_ID
Relative segment
C240
Segment part 4.
CSTART
Relative segment
C246 - C249
Segment part 9.
__program_start C246 ?reset_vector (?reset_vector)
Absolute parts (?ABS_ENTRY_MOD)
?cstart_begin C246 -
CSTART
Relative segment
C24A - C255
Segment part 12.
?cstart_init_zero C24A Enc28j60Bank (enc28j60)
NextPacketPtr (enc28j60)
buf (web)
data (main)
info_data_len (ip_arp_udp_tcp)
info_hdr_len (ip_arp_udp_tcp)
ipaddr (ip_arp_udp_tcp)
macaddr (ip_arp_udp_tcp)
plen (web)
strbuf (web)
CSTART
Relative segment
C256 - C265
Segment part 13.
?cstart_init_copy C256 ip (main)
port (main)
seqnum (ip_arp_udp_tcp)
wwwport (ip_arp_udp_tcp)
CSTART
Relative segment
C266 - C26D
Segment part 17.
Intra module refs   Segment part 9
?cstart_call_main C266 -
?cstart_end C26E -
?reset_vector
Library module
RESET
Relative segment
FFFE - FFFF
Segment part 0.
?reset_vector FFFE Segment part 9 (?cstart)
?Epilogue
Library module
<CODE> 1
Relative segment
D598 - D5A9
Segment part 0.
?Epilogue3 D5A2 checksum (ip_arp_udp_tcp)
make_tcphead (ip_arp_udp_tcp)
?Epilogue4 D5A0 enc28j60PacketReceive (enc28j60)
?Epilogue5 D59E -
?Epilogue6 D59C -
?Epilogue7 D59A itoa (web)
?Epilogue8 D598 -
?exit
Library module
<CODE> 1
Relative segment
D5DE - D5E1
Segment part 2.
exit
calls direct
D5DE Segment part 17 (?cstart)
?Cast32f32i
Library module
<CODE> 1
Relative segment
CC4E - CCDF
Segment part 0.
_Cast32sto32f CC4E -
_Cast32uto32f CC62 main (main)
_Cast32fto32u
Library module
<CODE> 1
Relative segment
D5CA - D5D5
Segment part 0.
_Cast32fto32u D5CA main (main)
?FLT_Extract
Library module
<CODE> 1
Relative segment
D062 - D0AD
Segment part 0.
?FLT_Extract D062 _Cast32fto32u (_Cast32fto32u)
_Mul32f
Library module
<CODE> 1
Relative segment
C7F6 - C905
Segment part 0.
_Mul32f C7F6 main (main)
_Div32f
Library module
<CODE> 1
Relative segment
C6C6 - C7F5
Segment part 0.
_Div32f C6C6 main (main)
_Add32f
Library module
<CODE> 1
Relative segment
C416 - C577
Segment part 0.
_Add32f C41A main (main)
_Sub32f C416 -
?Mul816
Library module
<CODE> 1
Relative segment
D34C - D37D
Segment part 0.
?Mul8 D34C -
?Mul16 D350 itoa (web)
?Mul16to32u D350 -
?DivMod816u
Library module
<CODE> 1
Relative segment
D4D0 - D4EB
Segment part 0.
?DivMod8u D4D0 -
?DivMod16u D4D4 Segment part 0 (?DivMod816s)
?DivMod816s
Library module
<CODE> 1
Relative segment
D318 - D34B
Segment part 0.
?DivMod8s D318 -
?DivMod16s D31C itoa (web)
?memcpy
Library module
<CODE> 1
Relative segment
D586 - D597
Segment part 2.
memcpy
D586 __data16_memcpy (?memzero)
?memzero
Library module
<CODE> 1
Relative segment
D5AA - D5BB
Segment part 4.
__data16_memzero
D5AA ?cstart_init_zero (?cstart)
<CODE> 1
Relative segment
D5DA - D5DD
Segment part 3.
__data16_memcpy
calls direct
D5DA ?cstart_init_copy (?cstart)
?strncmp
Library module
<CODE> 1
Relative segment
D408 - D42D
Segment part 2.
strncmp
D408 Web_serviceRequest (web)
Segments in Address Order
Segment Space Start End Size Kind Align
DATA16_AN 0003 - 0003 1 Relative 0
0021 - 0022 2
0026 - 0026 1
0029 - 002A 2
0041 - 0041 1
0056 - 0057 2
0068 - 006B 4
006E - 006F 2
0120 - 0121 2
01B0 - 01B5 6
DATA16_I 0200 - 0207 8 Relative 1
DATA16_Z 0208 - 039C 195 Relative 1
CSTACK 03B0 - 03FF 50 Relative 1
DATA16_AN 10FC - 10FD 2 Relative 0
DATA16_C C000 - C23C 23D Relative 0
DATA16_ID C23E - C245 8 Relative 1
CSTART C246 - C26D 28 Relative 1
<CODE> 1 C26E - D5E3 1376 Relative 1
RESET FFFE - FFFF 2 Relative 1
5 024 bytes of CODE memory
493 bytes of DATA memory (+ 25 absolute )
581 bytes of CONST memory
Errors: none Warnings: none
