- ; bike3.asm   Combines: Time , Dist, Av velocity, Inst Vel
- ;             Fred Maher             1st March 2002
- ;   BASIC BICYCLE  COMPUTER WITH THESE FUNCTIONS
- ; 1          Trip Time    HRS:MIN:SEC
- ; 2          Trip Dist    000km 00m
- ; 3          Trip AvSpd   00.00km/hr
- ; 4          Speed        00.00km/hr
- ;-------                 HEADER                ----------
- ;                      LCD MESSAGES
- ; position at beginning of 1st line col 0  movlw H'80
- ; position at beginning of second line     movlw H'C0'
-       LIST P=16F84           ;  16F84 Runs at 4.096 MHz
-       INCLUDE "p16f84A.inc"
-       __CONFIG    _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_ON
-       ERRORLEVEL -224        ;  suppress annoying message because of tris
-       ERRORLEVEL -302        ;  suppress message because of page change
- ; Define Information
-      #DEFINE RS PORTA, 2
-      #DEFINE E  PORTA, 3
-     ;#DEFINE TOGGLESW PORTB, 6  ; not used at the moment
-     ;#DEFINE LED PORTB, 5
- ;  Macro
-             CBLOCK     0CH   ;  0C to 4F = 67
- ;                   MATH ROUTINES
- ;                16 X16 Mult , --> 32
- ;     mah mal x mbh mbl = mq4 mq3 mq2 mq1 ( mq4 highest)
-  mq4
-  mq3
-  mq2
-  mq1
-  mbh
-  mbl
-  mah
-  mal
- ;                   16 / 16 Div --> 16
-  denlo
-  denhi
-  numlo
-  numhi
-  rmdrlo
-  rmdrhi
-  reshi
-  reslo
-  ;temp       also used in nybble
- ; Addition 16+16 out max 65536 (no carry)
- ; Subtraction q1_16-q2_16 out r_16; neg numbers not allowed
-  q1hi
-  q1lo
-  q2hi
-  q2lo
-  rhi
-  rlo
- ;------------    Distance         -----------------------
-  dtotlo       ; total trip distance in metres
-  dtothi           ; dtothi/lo hold a max of 65km 536m,
-  dtothi2      ; with this added max now 16777km
-  dist54       ; corrects +2m every 54m (27x2.0747 =56)
-  dm
-  dm1000
-  dm10000
-  dm100000
- ;------------   Average velocity Vav    -------------------
-  ;vavhi
-  ;vavlo
-  ;divrat
-  ;stemphi     ;second info passed to stemphi/lo
-  ;stemplo
-  ;dtemphi     ;dist info passed to dtemphi/lo
-  ;dtemplo
-  m
-  m10
-  m100
-  m1000
- ;---------   Time and trip time        --------------------
-  sectotlo        ; total trip seconds
-  sectothi        ; max 65536 = aprox 18hrs
-  sec             ; seconds digit
-  sec10           ; 10's of second digit
-  min             ; minutes digit
-  min10           ; 10's of minutes digit
-  hr              ; hours digit
-  hr10            ; 10's of hours digit
-  oldsec          ; holds last value of sec
-  cntmsec         ; count ms
-  TMR18           ; TMR0 217* TMR18 18 = 1 SEC
- ;----        isr interrupt service routine push pop  -------
-  w_temp          ; W isr var
-  status_temp     ; STATUS isr var
-  fsr_temp        ; FSR isr var
- ; ---------  Instantaneous Velocity  Vin  --------------------
-  vinhi
-  vinlo
-  sectemp
-  oldtemp
-  totmslo
-  totmshi
-  totms2lo
-  totms2hi
-  mshi
-  mslo
-  spdflg   ; 1st pass =0 2nd pass =1, diff is time between pulses
- ;--------         Miscellaneous     ------------------
-  temp            ; a temporary used in divide and nybble
-  count
-  menu
-        ENDC     ; end of definition block
-    ORG 0        ; start at location 0
-    goto main    ; jump over to main routine
-    ORG 4
-    goto Isr     ; jump to interrupt routine
- ;                           The Main routine                           ;
- ; --------       THE   MAIN MODULES    ---------
-       ;  Isr       stores elapsed TRIP time and generates hr:min:sec
-       ;  Disptime  TRIP time, to max 99:59:59
-       ;  Dist      Calculates total TRIP distance
-       ;  Dispdist  TRIP distance to a max of 999km 999m
-       ;  Velav     Average velocity, Totdist/totsecs max 99km/hr
-       ;  Dispvav   Average TRIP speed up to  99.99 km/hr
-       ;  Velocity  Speed   2m/(time diff of pulse2-pulse1)
-       ;  Dispd     Speed  up to 99.99km/hr
- ; NOTE. Speed is your  calculated velocity  every second
- ; --------    more to come??? NO, running out of space         ---------
- ;                           M A I N
- main:
-        call Init               ; Initialize ports, set up timer
-        call Initlcd          ; Initialize the LCD DUMMY
- Initend:
- ; Changesec Changewhlpulse wait for interrupts  newsec or newwheelpulse
-         clrf menu   ; initially set to 0 menu loop
-         clrf spdflg  ; Initially = 0 2nd =  sub for time  zero
-                          ; every new sec, set to zero
- ;              CHANGESEC  LOOPS TILL SEC CHANGES
-       ;clrw                          ;DUMMY
-       ;xorwf sec,w              ;DUMMY
-       ;btfsc STATUS,2       ;DUMMY
-       ;incf sec,f               ;DUMMY
- Changesec:               ;loops checking new sec and new wheel pulse
-      movf  oldsec, w
-      xorwf sec,w
-                   ; if equal, w= 0 and Z bit=1
-     btfsc STATUS,2    ; test Z bit
-     goto  Changesec  ; no change, loop
-     movf  sec,w          ; sec has  increased, update
-     movwf oldsec       ; sec and oldsec are = again
-     incf  menu,f          ; increases menu every sec
-             ; Note1, sectotlo/hi are updated every sec in ISR module
-             ; Note2, Decimal time also created in ISR module
-                              ; but time display for LCD  controlled
-                              ; the automatic menu below
-       call Disptime   ;TRIP time,  will appear on LCD top line
- Changewhp:          ; 1st detected wheelpulse starts menu sequence
-       clrf PORTB
-       bcf PORTB,5   ; start with green LED off
- loop:
-       btfss PORTB, 4  ;(PUT BTFSC FOR TEST); i/p hi,?DUMMY
-       goto loop            ; not yet
-                                  ; i/p hi detected
-                  ;green LED flashes with every wheel pulse
-       bsf PORTB, 5    ; LED on
-                                 ; wait a while to make sure switch has
-                                 ; settled
-       movlw D'10'      ; wait about 10 msec
-       call nmsec
-       btfsc PORTB, 4  ; will be lo (0) when finished
-       goto $ -1            ; still low
-                                 ; now must wait a make sure bouncing stopped
-       movlw D'10'       ; 10 milliseconds
-       call nmsec
-                                 ; and check again
-       btfsc PORTB, 4 ; if set, not finished
-       goto $ -5            ; still hi start debounce  wait again
- Tp1:                         ; green LED ready for next wheel pulse
-       bcf PORTB,5        ; i.e. LED off
-       movf PORTB,w  ; reading to clear
- ;              AUTOMATIC MENU: (LCD Top line always time)
-                 ; menu s at 10sec intervals in rotation
-                 ; Speed            menu  1 to 10
-                 ; Dist ance       menu 11 to 20
-                 ; Velav Avg vel menu 21 to 30
-                           ; MENU 0 TO 10
- ; as speed ( Speed) is stand alone, no sense in calculating it
- ; if it is not going to be displayed when menu is >10.
- ; BUT if SPEED AVERAGING IS TO BE USED,  kill off  the lines below that bypass
- ; the SPEED calc module
- Menucheck:
-       movlw 0x0A          ;check menu > 10  (to meet >10 AND =<20)
-       subwf menu,w
-       btfss STATUS,C   ;compare with 10
-       goto $+2               ;menucount =< 10 not yet got to 11 jump to Speed
-       goto Distblk
-       call Speed            ; Calculates instant speed,(time between pulses)
-       movlw 0x0A         ; DUMMY, was  movlw 0xA
-       subwf menu,w
-       call Spdflgcheck  ;menucount =< 10 ; also see 0-1 spdflg
-       goto Distblk
- Spdflgcheck:
-       clrw
-       xorwf spdflg,w
-       btfsc STATUS,Z
-       call Dispd        ;menucount =< 10 AND  spdflg =1
-       Return
- Distblk:
-       call Dist        ;menucount  > 10 skip Dispd update Dist
-                                   ; MENU 11 TO 20
-       subwf menu,w
-       goto $+5         ;menucount =< 10 not yet got to 11 jump to velav
-       movlw 0x14
-       subwf menu,w
-       btfss STATUS,C   ;compare with 20
-       call Dispdist    ;menucount =< 20
-       call Velav       ;menucount  > 20 skip dispdist update  Velav
-                           ; MENU 20 TO 30
-       movlw 0x14         ;check menu > 20  (to meet >20 AND =<30)
-       subwf menu,w
-       goto $+5             ;menucount =< 20 not yet got to 21 jump to NEXT
-       movlw 0x1E
-       subwf menu,w
-       btfss STATUS,C  ;compare with 30
-       call Dispvav         ;menucount =< 30
-       movlw 0x1F        ;if it has reached 31 reset menu, before return
-       xorwf menu,w
-       btfss STATUS,Z
-       goto $ +2           ; not 31 goto changewhp1 direct
-       clrf menu           ; is 31, reset menu before changewhp1
- Menuend:
-                                ; before changewhp jump, check that sec has not updated
-                                ; if it has , jump back to changesec routine
-       movf  oldsec, w
-       xorwf sec,w          ; if equal, w= 0 and Z bit=1
-       goto  Changewhp ; no sec change, check whpulse change
-       goto  Changesec  ; a new sec starts measurements
-                                    ; loop while NOT newsec
- ;                          End Main
- ; ISR, increments TMR0 by 1 every 256 ľsec. Basically just             ;
- ; reset the INTCON and TMR0 bits. The FSR,w, STATUS push pop kept      ;
- Isr:
-             movwf w_temp             ; save W
-             swapf STATUS,W        ; save status
-             movwf status_temp      ; without changing flags
-             swapf FSR,W               ; save FSR
-             movwf fsr_temp           ; without changing flags
-                                      ;256us * 217 * 18 = 0.999936 sec.
-                                      ;1hr_err = 0.23sec or 1 sec in 4hr
-   ;The time loop starts  with TMR0 loaded with  (256-217)=39 After 217
-   ;steps interrupt is set, TMR0 rolls to zero and the TMR18 inc +1
-             movlw D'39'           ;39 = 0x27
-             movwf TMR0
-             incf  TMR18,f
-             movlw D'18'          ; DUMMY18 = 0x12
-             xorwf TMR18,w    ; if equal, w= 0 and Z bit=1
-             btfss STATUS,2   ; test Z bit
-             goto  restore        ; NOT 18 so pop stack and return to main
- Firstsec:
-             clrf  TMR18          ; is 18. set TMR18 to zero and INC sec
-             incf  sec,f             ; also inc sectot (eventually lo and hi)
-             incf  sectotlo,f      ; check sectot lo 00->inc hi
-             clrw
-            xorwf sectotlo,w   ; if equal, w= 0 and Z bit=1
-             btfsc STATUS,2
-             incf sectothi,f      ; increases every 256 x sectotlo
-             movlw 0xA          ; check if =10
-            goto  restore        ; NOT 10 so pop stack and return to main
-             clrf sec               ; is 10. set sec to zero and inc sec10
-             incf sec10,f
-             movlw 0x6         ; = 0x6
-             xorwf sec10,w   ; if equal, w= 0 and Z bit=1
-             goto  restore      ; NOT 6 so pop stack and return to main
-             clrf  sec10         ; is 6. set sec10  to zero and INC min
-             incf  min,f
-             xorwf min,w     ; if equal, w= 0 and Z bit=1
-             clrf min                ; is 10. set sec to zero and inc min10
-             incf min10,f
-             movlw 0x6          ;= 0x6
-            xorwf min10,w     ; if equal, w= 0 and Z bit=1
-             clrf  min10         ; is 6. set min10  to zero and INC hr
-             incf  hr,f
-             movlw 0xA        ;check if =10
-             xorwf hr,w         ; if equal, w= 0 and Z bit=1
-             clrf hr                   ; is 10. set hr to zero and inc hr10
-             incf hr10,f
-             movlw 0xA          ;= 10
-             xorwf hr10,w       ; if equal, w= 0 and Z bit=1
-             clrf sec              ; is ten (99hr 59min 59sec +1sec) we are at MAX
-             clrf sec10          ;all reset to zero and start again
-             clrf min
-             clrf min10
-             clrf hr
-             clrf hr10
-             clrf TMR18
-             clrf oldsec
-             goto restore
- restore:
-             swapf status_temp,W      ; get original status back
-             movwf STATUS             ; into status register
-             swapf fsr_temp,W         ; get original fsr back
-             movwf FSR                  ; into status register
-             swapf w_temp,f           ; old no flags trick again
-             swapf w_temp,W         ; to restore W
-             bcf INTCON,T0IF        ; clear the TMR0 interrupt flag
-             retfie                           ; finished, reset GIE
- ;                       Initialize the ports                           ;
- Init:
-             clrf   PORTA
-             clrf   PORTB
-             movlw B'00000000'          ;  Porta all outputs
-             tris PORTA
-             movlw B'01010000'          ; 7o 6i-Wire 5o-LED 4i-multivib,
-             tris PORTB                     ; 0to3lcd
-             movlw B'00000111'          ;  opt pull-ups enabled
-                                                      ;  opt prescaler assigned to TMR18
-                                                      ;  opt prescaler set to 1:256
-             option                               ;  opt rolls over each 125th second
-  movlw 0                                       ;  zero out all registers
-  clrf m
-  clrf m10
-  clrf m100
-  clrf m1000
-  clrf dm
-  clrf dm1000
-  clrf dm10000
-  clrf dm100000
-  clrf totmshi
-  clrf totmslo
-  clrf totms2hi
-  clrf totms2lo
-  clrf dist54
-  clrf hr10
-  clrf hr
-  clrf min10
-  clrf min
-  clrf oldsec
-  clrf sec10
-  clrf sec
-  clrf sectotlo
-  clrf dtotlo
-  clrf dtothi
-  clrf sectotlo
-  clrf sectothi
-  clrf TMR18   ; when this reaches 18, 1 sec has elapsed
-             ; TMR0 has to start at 256-217 :39, so that the first rollover
-             ; with prescaler 256, happens in 217*256us =0.055552sec
-             ; The TMR18 incs each roll and after 18  1 sec has elapsed
-             movlw 0x27       ; D39
-             movwf TMR0    ; set to D39 217 counts later 256,
-                                      ; TMR0 resets and inc TMR18 in Isr loop
-            clrf  INTCON      ; START WITH ALL AT 0
-                                   ; movlw B'10100000'          ; GIE set T0IE set, T0IF cleared
-           movlw B'10100000' ; Set:GIE,T0IE,RBIE Clrd:T0IF,RBIF
-           movwf INTCON      ; ready to detect interrupts in ISR
-           return
- ;                 Initialize the LCD                                   ;
- Initlcd:
-   movlw D'40'
-   call   nmsec                  ;  Wait 40 msecs before Reset
-   bcf    RS                       ;  send an 8 bit instruction
-   movlw  0x03                 ;  Reset Command
-   call   NybbleOut          ;  Send the Nybble
-   call   Dlay5                  ;  Wait 5 msecs before Sending Again
-   call EStrobe
-   call Dlay160                ;  Wait 160 usecs before Sending 2nd Time
-   call EStrobe
-   call Dlay160                ;  Wait 160 usecs before Sending 3rd Time
-   movlw  0x02               ;  Set 4 Bit Mode
-   call   NybbleOut
-   call Dlay160
-   movlw  0x028                  ;  4 bit, 2 Line, 5x7 font
-   call   SendINS
-   movlw  0x010                  ;  display shift off
-   call   SendINS
-   movlw  0x001                  ;  Clear the Display RAM
-   call   SendINS
-   call   Dlay5                      ;  Note, Can take up to 4.1 msecs
-   movlw  0x006                  ;  increment cursor
-   call   SendINS
-   movlw  0x00C                 ;  display on cursor off
-   call   SendINS
-   return
- ;              Send the character in W out to the LCD                  ;
- SendASCII
-   addlw '0'                     ;  Send nbr as ASCII character
- SendCHAR:                  ;  Send the Character to the LCD
-   movwf  temp               ;  Save the temporary Value
-   swapf  temp, w           ;  Send the High Nybble
-   bsf    RS                     ;  RS = 1
-   call   NybbleOut
-   movf   temp, w            ;  Send the Low Nybble
-   bsf    RS
-   call   NybbleOut
-   return
- ;              ES strobe
- EStrobe:                ;  Strobe the "E" Bit
-   bsf    E
-   bcf    E
-   return
- ;              Send an instruction in W out to the LCD                 ;
- SendINS:                  ;  Send the Instruction to the LCD
-   movwf  temp           ;  Save w
-   swapf  temp, w       ;  send Hi Nybble
-   bcf    RS                 ;  RS to 0
-   call   NybbleOut
-   movf   temp, w        ;  Send Lo Nybble
-   bcf    RS
-   call   NybbleOut
-   return
- ;              Send the nibble in W out to the LCD                     ;
- NybbleOut:              ;  Send a Nybble to the LCD
-   movwf  PORTB
-   call EStrobe          ;  Strobe out the LCD Data
-   bsf    E
-   call Dlay160          ;  delay for 160 usec
-   return
- ;                   Output the message on the LCD                      ;
- OutMessage1:
-   movwf  FSR                    ;  Point at first letter
- OutLoop:
-   movf   FSR, w                 ;  Get pointer into W
-   incf   FSR, f                     ;  Set up for next letter
-   call   Dispmsg1               ;  Get character to output
-   iorlw  0                            ;  At the End of the Message?
-   btfsc  STATUS, Z            ;  Skip if not at end
-   return                              ;  Yes - Equal to Zero
-   call   SendCHAR             ;  Output the ASCII Character
-   goto   OutLoop                ;  Get the next character
- ;                    Data for message to be output                     ;
- Dispmsg1:                         ;  Message to Output
-   addwf  PCL, f                  ;  Output the Characters
-   dt     "Bike Computer", 0
- Dispmsg2:                       ;  Message to Output
-   dt     "Dist", 0
- Dispmsg3:
-   addwf PCL,f                 ; message to output
-   dt     " Av speed:",0      ; output characters
-  ;                        time delay routines                           ;
- ;Note . The original application needed precise times  the  delay code that
-  ; follows. But the Simple  Bike application does NOT use the routines for
-  ; any CRITICAL time measurement.
- Dlay160:
-   movlw D'41'                ;  delay about 160 usec
- micro4:
-  addlw H'FF'                ;  subtract 1  'W'
-  btfss STATUS,Z         ;  skip when you reach zero
-  goto micro4                ;  more loops
-  return
- Dlay5:
-  movlw 5                     ;  delay for 5 milliseconds
-  goto $ + 2
- msec250:
-  movlw D'250'              ; delay for 250 milliseconds
-                             ; --- N millisecond delay routine ---
- nmsec:
-  movwf cntmsec            ; delay for N (you put in W) millisec
- msecloop:
-  movlw D'254'               ; load takes .9765625 microsec
-  call micro4                  ; by itself CALL takes ...
-                                     ; about 1ms
-  nop                             ; 1usec
-  decfsz cntmsec, f       ; .98 skip not taken, else 1.95
-  goto msecloop           ; 1.95 here: total ~1000 / loop
-  return                         ; final time through ~999 to here
-                                    ; overhead in and out ignored
-                                   ; this block is functional for tests, but not used in bike
- Dlay1sec:          ; this is a marker routine to see where
-  call msec250             ; the prg is at.
- ; bsf  LED
-  call msec250          ;flash led on portb pin6
- ;bcf  LED
-  call msec250
- ; bsf  LED
-  call msec250   ; finishes with green led lit
-  return
- ;                       Display the Time                               ;
- Disptime:
-  movlw H'80'        ;  position at beginning of first line
-  call SendINS
-  movf hr10, W      ;  tens of hours
-  call SendASCII
-  movf hr, W          ;  hours
-  call SendASCII
-  movlw ":"
-  call SendCHAR
-  movf min10, W    ;  tens of minutes
-  call SendASCII
-  movf min, W        ;  minutes
-  call SendASCII
-  movlw ":"
-  call SendCHAR
-  movf sec10, W    ;  tens of seconds
-  call SendASCII
-  movf sec, W       ;  seconds
-  call SendASCII
-  movlw " "
-  call SendCHAR   ; the h m s really not needed
-  movlw "h"
-  call SendCHAR
-  movlw "m"
-  call SendCHAR
-  movlw "s"
-  call SendCHAR
-  movlw " "
-  call SendCHAR
- Dispend:
-               RETURN
- ;               End of display time
- ;                    Display the Distance , (trip distance at moment)                               ;
- Dispdist:
-  movlw H'C0'       ;  position at beginning of second line
-  call SendINS
-  movf dm100000, W     ;  0 of 065km 536m
-  call SendASCII
-  movf dm10000, W      ;  6 of 065km 536m
-  call SendASCII
-  movf dm1000, W       ;  5 of 065km 536m
-  call SendASCII
-  movlw "k"                 ;  k of 065km 536m
-  call SendCHAR
-  movlw "m"                ;  m of 065km 536m
-  call SendCHAR
-  movlw " "                  ;  " " of 065km 536m
-  call SendCHAR
-  movf  dm100- ,W         ;   5-  of 065km 536m
-  call SendASCII
-  movf  dm10- ,W          ;   3-  of 065km 536m
-  call SendASCII
-  movf dm, W             ;  6 of 065km 536m
-  call SendASCII
-  call SendCHAR
-  movlw " "                 ; " "
-  call SendCHAR
-  movlw "D"               ; "D "
-  call SendCHAR
-  movlw "i"                ; " i"
-  call SendCHAR
-  movlw "s"               ; "s "
-  call SendCHAR
-  movlw "t"                ; " t"
-  call SendCHAR
-  movlw " "               ; " " ( to wipe screen)
-  call SendCHAR
- Distend:
-               RETURN
- ;                Multiplication  16x16 Out32
- Mult16x16:
-         clrf mq4
-         clrf mq3
-         clrf mq2
-         clrf mq1
-         bsf mq2, 7
- Mu1:
-         rrf mah, f
-         rrf mal, f
-         skpc
-         goto Mu2
-         movf mbl, w
-         addwf mq3, f
-         movf mbh, w
-         skpnc
-         incfsz mbh, w
-         addwf mq4, f
- Mu2:
-         rrf mq4, f
-         rrf mq3, f
-         rrf mq2, f
-         rrf mq1, f
-         skpc
-         goto Mu1
- Endmult16:
-       clrf mbh
-       clrf mbl
-       clrf mah
-       clrf mal
-         Return
- ;            End Multiplication   16x16 Out32
- ;       New routine Division  16/16 Out 16
- ; Finally:- Result 000AH in reshi/lo, remainder 0096H in rmdrhi/lo
- ; so, checking end of division A=10 and 96H/E1H= 150/225 =0.666  OK
- Div:
-        call    D_divS          ; remainder in Rmdr.
- Divend:
-           nop
-           return
- D_divS:
-         call    setup
-         clrf    rmdrhi
-         clrf    rmdrlo
- dloop:
-       bcf     STATUS,C
-         rlf     reslo, f
-         rlf     reshi, f
-         rlf     rmdrlo, f
-         rlf     rmdrhi, f
-         movf    denhi,w
-         subwf   rmdrhi,w      ;check if a>c
-         btfss   STATUS,Z
-         goto    nochk
-         movf    denlo,w
-         subwf   rmdrlo,w      ;if msb equal then check lsb
- nochk:
-         btfss   STATUS,C    ;carry set if c>a
-         goto    nogo
-         movf    denlo,w        ;c-a into c
-         subwf   rmdrlo, f
-         btfss   STATUS,C
-         decf    rmdrhi, f
-         movf    denhi,w
-         subwf   rmdrhi, f
-         bsf     STATUS,C    ;shift a 1 into b (result)
- nogo:
-                 rlf     numlo,f
-         rlf     numhi,f
-         decfsz  temp, f        ;loop untill all bits checked
-         goto    dloop
- setup:
-                 movlw   .16             ; for 16 shifts
-         movwf   temp
-         movf    numhi,w      ;move Num to Res
-         movwf   reshi
-         movf    numlo,w
-         movwf   reslo
-         clrf    numhi
-         clrf    numlo
-         retlw   0
-  ;--------------------------End Div 16 by 16----------------------------
-         return
- ; END DIVISION  16/16 OUT 16
- ; START Addition  16-16 OUT 16
- Add:  ; R = q1 + q2
-         movf q1lo, W
-         addwf q2lo, W
-         movwf rlo
-         movf q1hi, W
-         btfsc STATUS, C
-         addlw .1                ; If A Carry Occurred, Add 1
-         addwf q2hi, W
-         movwf rhi
-         ;clrf q1hi                  ; added this to stop next user summing;
-         ;clrf q1lo
-         ;clrf q2hi
-         ;clrf q2lo
-         Return
- ; END Addition  16-16 OUT 16
- ; START Subtraction  16-16 OUT 16
- Sub:    ; R = q1 - q2
-         movf q2lo, W
-         subwf q1lo, W   ; W = q1lo - q2lo
-         movwf rlo
-         btfss STATUS, C
-         Goto Borrow
-         Goto Sub1
- Borrow:
-         Decf q1hi, F
- Sub1:
-         movf q2hi, W
-         subwf q1hi, W   ; W = q1hi - q2hi
-         movwf rhi
-         Return
- ; END Subtraction  16-16 OUT 16
- ;                 Dist = counting wheel pulses
- Dist:                ; whlcirc = 2.0747, for initial test =2
-                       ; movlw 0x2          ; <-- don't forget, this is just for 26"wheel
-                       ; movwf whlcirc  ; start count at 0 and inc till same as whlcirc
-                       ; (range will be 1 to 4 m)
-          clrf count     ;  count can be 2 or 4 in this 26" case
- Whloop:            ; although the distance pulses ( in this example) jump in steps of 2m
-                          ; the m counter has to increase in 1's to catch the
-                  ; decimal rollover  10 to 0
-                          ; so count, here, is stepped  0 to 2 (whlcirc)
-                          ; Also, when the dist54 var increases 54m, COUNT adds an  extra 2m
-                          ; to the hex and decimal totals, before resetting to zero.
-                 ; Note that as dist54 is in the loop it will also receive
-                  ; the 2m increase so it  really  counts to 56 (54 +2).
-        movlw 0x2               ; wheel circumference  of 26 inch
-        xorwf count,w          ; if equal, w= 0 and Z bit=1
-        goto DistanceEnd    ; they are the same, so jump distanceEnd and return
-        goto Mcount            ; NOT  yet = whlcirc, so inc mcount by 1 and  return
- Mcount:       ; Distance to decimal for display , i/p m, o/p 000km 000m
-             ; starts  with m, m10, m100, m1000 , m10000, m100000 = 0
-             ; Later correct m every 54m (add 2m ???? )
-       incf dm,f
-       movlw D'10'
-       xorwf dm,w           ; if equal, w= 0 and Z bit=1
-       goto Mcountend   ; NOT 0 so return
-       clrf dm
-       movlw D'10'
-       xorwf  dm10- ,w      ;  if-  equal, w=  0-  and Z bit= 1
-       movlw D'10'
-       xorwf  dm100- ,w     ;  if-  equal, w=  0-  and Z bit= 1
-     incf dm1000,f
-       movlw D'10'
-       xorwf dm1000,w    ; if equal, w= 0 and Z bit=1
-       clrf dm1000
-       incf dm10000,f
-       movlw D'10'
-       xorwf dm10000,w   ; if equal, w= 0 and Z bit=1
-       clrf dm10000
-       incf dm100000,f
-       movlw D'10'
-       xorwf dm100000,w  ; if equal, w= 0 and Z bit=1
-       clrf dm                     ; is distmax, reset to 0
-       clrf dm1000
-       clrf dm10000
-       clrf dm100000
-       goto Mcountend  ; see if whpl  update is now finished
- Mcountend:  ;update the hex counters dtot /lo/hi/hi2
-       incf dtotlo,f
-       clrw
-       xorwf dtotlo,w       ; if equal, w= 0 and Z bit=1
-       goto Dtotend        ; dtotlo NOT 0
-       incf dtothi,f           ; add 1, dtotlo is 0
-       clrw
-       xorwf dtothi,w      ; if equal, w= 0 and Z bit=1
-       goto Dtotend        ; dtothi NOT 0
-       incf dtothi2,f         ; add 1, dtothi is 0
- Dtotend:
-       movlw D'54'
-       movwf numhi       ; not in use here, use to store 54
-       movf  dist54,w
-       subwf numhi,w
-       btfsc STATUS,C
-       goto  Noextra      ; dist54=< 53, don't freeze COUNT
-       movlw D'56'        ; dist54>53   add 2 extra counts
-       movwf numhi      ; not in use here to store 56
-       movf  dist54,w
-       subwf numhi,w
-       btfsc STATUS,C
-       goto  Extra          ; dist54=< 56, freeze COUNT
-       clrf dist54
-       goto Noextra
- Noextra:
-      incf dist54,f
-      incf count,f
-     goto Whloop
- Extra:                          ; an extra loop BUT count is NOT increased
-     incf dist54,f
-    goto Whloop
- DistanceEnd:  ;  All conversion loops have executed and
-                        ; only left to display in decimal, when ed
-   return          ; BACK TO MAIN
- ;              End of Trip  Distance calculation Module
- ;     Calculate Average velocity  Velav = totdist/totsec
- ; 1st time round distto = 0 and sectot =0.
- ; Disttot lo/hi zero is prob OKbut test sec=0. If zero return
- Velav:
-      clrw
-      xorwf sectotlo,w
-      btfss STATUS,Z
-      goto  Spdstart     ; not 0, onto Avspeed calc
-      clrw                ; lo was 0, but hi byte may not be
-      xorwf sectothi,w
-      btfss STATUS,Z
-      goto  Spdstart     ; was not 0, onto Avspeed calc
-       ;incf  sectotlo,f   ; DUMMY
-       ;goto  Spdstart   ; DUMMY
-       return             ; was also 0, abort module  wait for sec inc
-                 ; to slow down the number of whpul in the test we add Dummies
- Spdstart:                 ; for test delay incf sec and sectot, gives 7.2km/hr
-       ;incf  sec,f        ; DUMMY
- ;Lpstart:
-       movlw 0x07                 ; 1800   comp hi bytes
-       subwf dtothi,w
-       btfsc STATUS,C
-       goto  Divratio      ;  dtothi is > 1800hi and needs dividing
-                          ;  we suppose that the hibyte test is sufficient,
-                  ;  it may not be true. e.g hi's the same but lo's diff
-                                 ;  pass dtot to m1000,m100
-     movf dtothi,w        ; dtothi <1800
-     movwf m1000
-     movf dtotlo,w
-     movwf m100         ; m1000,m100 hold dtothi/lo ( no div needed)
-     movf  sectothi,w
-     movwf m10
-     movf sectotlo,w
-     movwf m             ; m10,m hold sectothi/lo ( no div needed)
-                        ; note, this is dtot to m1000,m100 not needing division
-     goto  Ratend       ; if divratio is needed, then m1000,m100 is used there
- Divratio:                   ; enter variables and 1800
-       movf  dtothi,w
-       movwf numhi
-       movf  dtotlo,w
-       movwf numlo
-       movlw 0x07
-       movwf denhi
-       movlw 0x08
-       movwf denlo
-       call  Div
-       incf  reslo,w    ; reslo holds INT of Divratio +1
-       movwf count   ; not used at the moment
-       movf  dtothi,w ; divide dtothi/lo by count
-       movwf numhi
-       movf  dtotlo,w
-       movwf numlo
-       clrf  denhi
-       movf  count,w  ; e.g. D 37
-       movwf denlo
-       call  Div          ; we need parking space for results, REuse the m1000 etc
-       movf  reshi,w
-       movwf m1000 ;
-       movf  reslo,w
-       movwf m100   ; m1000, m100 =dtot/count
-                             ; repeat for sectot
-       movf  sectothi,w
-       movwf numhi
-       movf  sectotlo,w
-       movwf numlo
-       clrf  denhi
-       movf  count,w    ; e.g D 37
-       movwf denlo
-       call  Div
-       movf  reshi,w
-       movwf m10
-       movf  reslo,w
-       movwf m         ; m10, m =sectot/count
- Ratend:
-  ;    WE CAN NOW DO DTOT/SECTOT x3.6  as we have SCALED TO AVOID OVERFLOW
-  ;                m1000,m100   x 36   (top line)
-  ;     Vav=   -------------------------                      = Average speed in km/hr
-  ;               m10,m        x 10   (bottom line)         ;     36(24H), 10(AH)
-       movf m1000,w     ; MULT dtot, top line,  by 24H
-       movwf mah
-       movf m100,w
-       movwf mal
-       clrf  mbh
-       movlw 0x24
-       movwf mbl
-       call  Mult16x16  ; ( store top line result in the same variables)
-       movf  mq2,w
-       movwf m1000
-       movf  mq1,w
-       movwf m100    ;  dtot x 36
-      movf m10,w      ; MULT sectot, bottom line,  by AH
-      movwf mah
-      movf m,w
-      movwf mal
-       clrf  mbh
-       movlw 0xA
-       movwf mbl
-       call  Mult16x16 ; ( store bottom line result in the same variables)
-       movf  mq2,w
-       movwf m10
-       movf  mq1,w
-       movwf m         ;  sectot x 10
- Tp3:
-        ; As we are reusing variables, trying to show where the results to here are being held
-  ;                                      m1000,m100
-  ;   We now have as  Average speed     ----- ---------       km/hr
-  ;                                                              m10,m
-    ;the AVERAGE SPEED AT LAST
-       movf  m1000,w  ; dtotx36/sectotx10
-       movwf numhi
-       movf  m100,w
-       movwf numlo
-       movf  m10,w
-       movwf denhi    ; needed below for decimal place
-      movf  m,w
-      movwf denlo    ; needed below for decimal place
-      call  Div
-                              ; denhi/lo can chanfge as the div routine reuses bits
-                     ; so we reestablish previous denom values before losing
-     movf  m10,w
-     movwf denhi
-     movf  m,w
-     movwf denlo   ; we can now write over m and m10
-     movf  reshi,w  ;will be zero
-                    ;(bikes don't exceed 256km/hr normally)
-     movf  reslo,w  ; reuse variables m10 INT and later m FRAC
-     movwf m10     ;we have integer part of Vav Average speed
-                          ; rmdrhi/lo holds decimal fraction.we will only use 1 decimal place.
-                 ; so mult the rmdrhi,lo x10  before dividing by denhi/lo
-   movf  rmdrhi,w     ; mult top by 10
-   movwf mah
-   movf  rmdrlo,w
-   movwf mal           ; rmdr in tot storage
-   clrf  mbh
-   movlw 0xA
-   movwf mbl
-   call  Mult16x16  ; rmdrhi,lo x 10
-                             ; top line is now  mq2,mq1 ( nothing in mq4,mq3)
-                             ; Bottom line..remember we already have loaded
-                            ; the denominator above which says
-                             ; " needed below for decimal place"
- Tp4:
- movf mq2,w       ;rmdrhi,w
-     movwf numhi
-     movf  mq1,w        ;rmdrlo,w
-     movwf numlo
-     call Div                ; div for the decimal( just 1 place), in reslo
-                 ; reshi,reslo holds decimal place results
-                                 ; m10+m are  av speed as INT+DEC but in hex
-                                ; now change to decimal.
-                                ; m10 and m are going to be wiped, but there is no
-                                ;divide routine so for INT +FRAC we use reshi reslo
-       movf  m10,w
-       movwf reshi      ; OK? yes reshi +reslo = INT+FRAC in hex, convert
- Vavh2d:
-      clrf m
-      clrf m10
-     clrf count
- Vavloh2d:                ; m is 2nd dec, use m10
-        movf  count,w
-        xorwf reslo,w
-        btfsc STATUS,Z
-        goto  Vavloend
-        incf  count,f
-          incf  m10,f
-        movlw 0xA
-        xorwf m10,w
-        btfss STATUS,Z
-        goto Vavloh2d
-        clrf m10
-        incf m,f
-        goto Vavloh2d
- Vavloend:
-       clrf m100
-       clrf m1000
-       clrf count
- Vavhih2d:
-        movf  count,w
-        xorwf reshi,w
-        btfsc STATUS,Z
-        goto  Vavhiend
-        incf  count,f
-        incf  m100,f
-        movlw 0xA
-        xorwf m100,w
-        btfss STATUS,Z
-        goto Vavhih2d
-        clrf m100
-        incf m1000,f
-        goto Vavhih2d
- Vavhiend:                 ; We have Vav as: INT m1000,m100 and FRAC  m10,m with Frac
- Vavend:
-          nop
-          return
- ;                    Display the Average velocity                               ;
- Dispvav:
-  call SendINS
-  movf m1000, W     ;    x0 tens of km
-  call SendASCII
-  movf m100,W         ;   0x ones of km
-  call SendASCII
-  movlw "."                 ;  "." punto decimal
-  call SendCHAR
-  movf m10,W             ;  "0.x0" decimal
-  call SendASCII
-  movf m, W              ;  "0.0x" decimal
-  call SendASCII
-  movlw "k"                   ;  k
-  call SendCHAR
-  movlw "m"                 ;  m
-  call SendCHAR
-  movlw "/"                   ;  /
-  call SendCHAR
-  movlw "h"                  ;  h
-  call SendCHAR
-  movlw "r"                   ;  r
-  call SendCHAR
-  movlw " "                   ;  " "
-  call SendCHAR
-  movlw "V"                ;  V
-  call SendCHAR
-  movlw "e"                  ;  e
-  call SendCHAR
-  movlw "l"                  ;  l
-  call SendCHAR
-  movlw "A"                 ;  A
-  call SendCHAR
-  movlw "v"                 ;  v
-  call SendCHAR
-  movlw "g"                 ;  g
-  call SendCHAR
-  movlw " "                   ;  " "
-  call SendCHAR
- Dispvavend:
-   Return                    ; to change seconds for next second
- ;--------------END OF AV SPEED-------------------
- ;                   Instantaneous Speed
-  ;  Previous time values  are subtracted    the present
-  ;  sec, TMR18, TMR0 values.
-  ;  This time difference is the time between
-  ; wheel pulses. This in turn for 26" wheel is a distance of 2.0747m
-  ; is covered in totms
- ; Note sec can only move between  0 and 9, 10 is a new 0
- ; We start by reading sec, TMR18, TMR0 TO GET START TIME
- Speed:
- Spdflg0:                  ; FIRST TIMEwith spdflg=0, second time with spdflg=1
-                               ; First time captures timezero 0 in ms in totms
-         clrw
-         xorwf spdflg,w
-         btfss STATUS ,Z
-         goto Spdflg1    ; spdflg is not 0, this is the second time
-       call Summs
-       movf  mshi,w
-       movwf totmshi
-       movf  mslo,w
-       movwf totmslo
-       incf spdflg,f  ; (spdflg = 1 for  SECOND TIME)
-       return   ;jump back to main menu
- Summs:   ; this routine is common to the first and second time
-       movf sec,w     ; spdflg = 0
-       movwf mbl      ; sec can only be in range 0 to 9
-       clrf  mbh
-       movlw 0x03                ; 1000 = 03E8
-       movwf mah
-       movlw 0xE8                ; 1000 = 03E8
-       movwf mal
-         call  Mult16x16 ;
-       movf  mq2,w    ; hi byte
-       movwf mshi
-       movf  mq1,w    ; lo byte
-       movwf mslo
-         movf  TMR18,w
-         movwf mal
-         clrf  mah
-       movlw D'56'
-       movwf mbl
-       clrf  mbh
-         call  Mult16x16 ;  after themult we add
-         movf  mshi,w
-         movwf q1hi
-         movf  mslo,w
-         movwf q1lo
-         movf  mq2,w
-         movwf q2hi
-         movf  mq1,w
-         movwf q2lo
-         call  Add
-         movf  rhi,w
-         movwf mshi
-         movf  rlo,w
-         movwf mslo   ; sum  (sec +TMR18)
-                          ;TMR0 is a little more complex as we have to subtract39
-                          ; before we can calculate ms in TMR0
-         movf  TMR0,w
-         movwf q1lo
-         clrf  q1hi
-         movlw  D'39'
-         movwf q2lo
-         clrf q2hi
-         call Sub
-         movf rlo, w
-         movwf numlo
-         clrf  numhi
-         movlw 0x4
-         movwf denlo
-         clrf  denhi
-         call  Div
-         movf  mshi,w
-         movwf q1hi
-         movf  mslo,w
-         movwf q1lo
-         movf  reshi,w
-         movwf q2hi
-         movf  reslo,w
-         movwf q2lo
-         call  Add
-         movf  rhi,w
-         movwf mshi
-         movf  rlo,w
-         movwf mslo ;   ( SEC +TMR18+ TMR0) in ms mshi/lo
-         RETURN     ; Summs
- Summsend:
- Spdflg1: ; SECOND TIME is with spdflg =1
-                          ; Second time captures timezero to  2nd Pulse
-                      ; in ms, store  in totms2
-                      ; for test we add 250ms to simulate time between
-                      ; wheel pulses
-                      ; 250ms delay
-       ;movlw D'63'   ; DUMMY FOR TEST
-       ;call nmsec     ; DUMMY FOR TEST
-         call Summs
-       movf  mshi,w   ;
-       movwf totms2hi ;
-       movf  mslo,w    ;
-       movwf totms2lo  ;
- ; totms2 should be larger than totms,however if totms2 has just rolled,
- ; then add 10000 to tot2
- Testtot2:
-        movf  totms2hi,w
-        subwf totmshi,w
-        btfss STATUS,C   ;compare for greater
-        goto  Diffms     ;totms2 > totms  no add 10000 needed
-        movlw 0xA        ;totms2 < totms, add 10000, hex 2710
-          movlw 0x27
-        movwf q1hi
-          movlw 0x10
-        movwf q1lo
-        movf totms2hi,w
-          movwf q2hi
-        movf totms2lo,w
-          movwf q2lo
-        call  Add     ; tot2 +10000
-          movf  rhi,w
-        movwf totms2hi
-          movf  rlo,w
-        movwf totms2lo  ; tot2 = tot2+10000
- Diffms:
-      ; sub  (tot2-tot1)for time between wheel pulses
-         movf   totms2hi,w  ;
-       movwf  q1hi
-         movf   totms2lo,w
-       movwf  q1lo
-         movf   totmshi,w
-       movwf  q2hi
-         movf   totmslo,w
-       movwf  q2lo
-       call   Sub  ; result is  time diff, stored in rhi, rlo
- tp2:
-    ; we are almost ready to divide dist/time for speed
-    ; complete equation is dist/time x3.6
-    ; to avoid as far as possible fractions we multiply before divide
-    ; but this time, better divide first.
-    ; 2000            36        <--- this is more than 65536
-    ; ----       x    --------
-    ; denhi/lo         10    ( denhi/lo is sub result rhi/lo)
-    ; so we can divide by 10 and x by 36 ( always,)
-    ; so top  line is simply 7200.
-    ; we finally have 7200/(denhi/lo) , SPEED IN HEX
-       movf   rhi,w
-         movwf  denhi
-       movf   rlo,w
-         movwf  denlo  ; denom is time in hex
-       movlw  0x1C   ; 7200, hex 1C20
-       movwf  numhi
-       movlw  0x20   ; 7200, hex 1C20
-       movwf  numlo
-         call Div
-                     ; the result , res, is  more than 1
-                         ;and a remainder rmdr/den
-                     ;we now have 6 free variables
-                     ; mshi/lo  for INT hex speed lo is enough
-                         ; totmshi/lo
-                         ; totms2hi/lo
-                     ;we will reuse to convert  hex to decimal
-         movf  reslo,w
-       movwf mshi   ; INT part of hex speed ( hi, because FRAC will be in lo)
-                     ;we will only use 1 decimal of
-                         ;the hex speed remainder, so 1st  rmdrx10
-                     ;  so next calculation is
-                           ; 10 x rmdrhi/lo
-                       ; denhi/lo
-       movf rmdrhi,w
-       movwf mah
-       movf rmdrlo,w
-       movwf mal
-         clrf  mbh
-         movlw 0x0A
-         movwf mbl
-       call  Mult16x16  ;( ten times top)
-       movf  mq2,w
-       movwf numhi
-       movf  mq1,w
-       movwf numlo  ; the den is previously loaded so divide for
-                    ; decimal part of speed ( still in hex)
-         call  Div    ; we only use 1 decimal, so just use lo of Div result
-       movf  reslo,w
-       movwf mslo    ; FRAC  of speed in hex
-                    ; now convert speed to decimal form
-                    ; i.e. mshi, mslo --> 99.9 km/hr
- Spdh2d:
-         clrf m
-         clrf m10
-         clrf m100
-         clrf m1000
-         clrf count
- Spdlo:
-        movf  count,w
-        xorwf mslo,w
-        btfsc STATUS,Z
-        goto  Spdhicnt
-        incf  count,f
-          incf  m10,f
-        movlw 0xA
-        xorwf m10,w
-        btfss STATUS,Z
-        goto Spdlo
-        clrf m10
-        incf m,f
-        goto Spdlo
- Spdhicnt:
-         clrf m100
-         clrf m1000
-         clrf count
- Spdhi:
-        movf  count,w
-        xorwf mshi,w
-        btfsc STATUS,Z
-        goto  Spdhiend
-        incf  count,f
-          incf  m100,f
-        movlw 0xA
-        xorwf m100,w
-        btfss STATUS,Z
-        goto Spdhi
-        clrf m100
-        incf m1000,f
-        goto Spdhi
- Spdhiend:; We have filled m1000,m100 with INT and m10,m with Frac, of Vin.
-          ; Note we only need m10 ( 1 decimal place)
-       clrf spdflg ; reset to 0 for next pair of pulses
-      ; incf spdflg,f  ; (spdflg = 1 for  SECOND TIME)
-         return
- ;                         End of Instantaneous Speed
- Dispd:
- ;                    Display the Instantaneous Speed (Speed)                               ;
-  call SendINS
-  call SendASCII
-  call SendASCII
-  call SendCHAR
-  call SendASCII
-  call SendASCII
-  movlw "k"         ;  k
-  call SendCHAR
-  movlw "m"         ;  m
-  call SendCHAR
-  movlw "/"         ;  /
-  call SendCHAR
-  movlw "h"         ;  h
-  call SendCHAR
-  movlw "r"         ;  r
-  call SendCHAR
-  movlw " "         ;  " "
-  call SendCHAR
-  movlw "S"         ;  S
-  call SendCHAR
-  movlw "p"         ;  p
-  call SendCHAR
-  movlw "e"         ;  e
-  call SendCHAR
-  movlw "e"         ;  e
-  call SendCHAR
-  movlw "d"         ;  d
-  call SendCHAR
- Dispdend:
- ;--------------END OF Inst SPEED-------------------
-      end
- ;             bike computer program end  ....enjoy
- ;                    WORK IN HAND
- ; CLEAN UP  SPEED,  readout still a little jumpy,
- ; can try integrating but need more space. Next version
- ;           Coventions used in the program text.
-  ;Variables all small letters , exceptions, those defined
-  ; by microchip. e.g. STATUS
-  ;Labels: First letter always a Capital, exceptions imported
-  ; routines
-  ; Test points. These have  a comment DUMMY, the value of the code
-  ; has/had been changed for testing or simulating.  If YOU want
-  ;to polish  these points should be useful for value changes
-  ; example. In ISR the D'18' value to reach a sec is very slow.
-  ;Use for test , say 2, and you get going about 10 times  faster.
-  ;Also LCD INIT: can be bypassed to debug quicker
- ;                   End of the Simple Bike Computer
