#include <SPI.h>
#include <Ethernet.h>
#include <TextFinder.h>
#include <EEPROM.h>
#include <avr/pgmspace.h>
//seting up the EthernetShield
//change the defaults the match your own network
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip[] = {10,5,1,20};
byte subnet[] = {255,255,255,0};
byte gateway[] = {10,5,1,1};
EthernetServer server(20000);
// This is our buffer through which we will will "flow" our HTML code.
// It has to be as big as the longest character chain +1 including the "
char buffer[200];
// This is the HTML code all chopped up. The best way to do this is, is by typing
// your HTML code in an editor, counting your characters and divide them by 8.
// you can chop your HTML on every place, but not on the \" parts. So remember,
// you have to use \" instead of simple " within the HTML, or it will not work.
prog_char htmlx0[] PROGMEM = "<html><title>Ethernet Setup</title><body marginwidth=\"0\" marginheight=\"0\" ";
prog_char htmlx1[] PROGMEM = "leftmargin=\"0\" style=\"margin: 0; padding: 0;\"><table bgcolor=\"#008080\" border";
prog_char htmlx2[] PROGMEM = "=\"0\" width=\"100%\" cellpadding=\"1\" style=\"font-family:Verdana;color:#fff";
prog_char htmlx3[] PROGMEM = "fff;font-size:12px;\"><tr><td>  BEÁLLÍTÁS</td></tr></table><br>";
PROGMEM const char *string_table0[] = {htmlx0, htmlx1, htmlx2, htmlx3};
prog_char htmla0[] PROGMEM = "<script>function hex2num (s_hex) {eval(\"var n_num=0X\" + s_hex);return n_num;}";
prog_char htmla1[] PROGMEM = "</script><table><form><input type=\"hidden\" name=\"SBM\" value=\"1\"><tr><td>MAC:";
prog_char htmla2[] PROGMEM = "<input id=\"T1\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT1\" value=\"";
prog_char htmla3[] PROGMEM = "\">.<input id=\"T3\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT2\" value=\"";
prog_char htmla4[] PROGMEM = "\">.<input id=\"T5\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT3\" value=\"";
prog_char htmla5[] PROGMEM = "\">.<input id=\"T7\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT4\" value=\"";
prog_char htmla6[] PROGMEM = "\">.<input id=\"T9\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT5\" value=\"";
prog_char htmla7[] PROGMEM = "\">.<input id=\"T11\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT6\" value=\"";
PROGMEM const char *string_table1[] = {htmla0, htmla1, htmla2, htmla3, htmla4, htmla5, htmla6, htmla7};
prog_char htmlb0[] PROGMEM = "\"><input id=\"T2\" type=\"hidden\" name=\"DT1\"><input id=\"T4\" type=\"hidden\" name=\"DT2";
prog_char htmlb1[] PROGMEM = "\"><input id=\"T6\" type=\"hidden\" name=\"DT3\"><input id=\"T8\" type=\"hidden\" name=\"DT4";
prog_char htmlb2[] PROGMEM = "\"><input id=\"T10\" type=\"hidden\" name=\"DT5\"><input id=\"T12\" type=\"hidden\" name=\"D";
prog_char htmlb3[] PROGMEM = "T6\"></td></tr><tr><td>IP: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT7\" value=\"";
prog_char htmlb4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT8\" value=\"";
prog_char htmlb5[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT9\" value=\"";
prog_char htmlb6[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT10\" value=\"";
PROGMEM const char *string_table2[] = {htmlb0, htmlb1, htmlb2, htmlb3, htmlb4, htmlb5, htmlb6};
prog_char htmlc0[] PROGMEM = "\"></td></tr><tr><td>MASK: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT11\" value=\"";
prog_char htmlc1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT12\" value=\"";
prog_char htmlc2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT13\" value=\"";
prog_char htmlc3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT14\" value=\"";
PROGMEM const char *string_table3[] = {htmlc0, htmlc1, htmlc2, htmlc3};
prog_char htmld0[] PROGMEM = "\"></td></tr><tr><td>GW: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT15\" value=\"";
prog_char htmld1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT16\" value=\"";
prog_char htmld2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT17\" value=\"";
prog_char htmld3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT18\" value=\"";
prog_char htmld4[] PROGMEM = "\"></td></tr><tr><td><br></td></tr><tr><td><input id=\"button1\"type=\"submit\" value=\"MENTÉS\" ";
prog_char htmld5[] PROGMEM = "></td></tr></form></table></body></html>";
PROGMEM const char *string_table4[] = {htmld0, htmld1, htmld2, htmld3, htmld4, htmld5};
prog_char htmle0[] PROGMEM = "Onclick=\"document.getElementById('T2').value ";
prog_char htmle1[] PROGMEM = "= hex2num(document.getElementById('T1').value);";
prog_char htmle2[] PROGMEM = "document.getElementById('T4').value = hex2num(document.getElementById('T3').value);";
prog_char htmle3[] PROGMEM = "document.getElementById('T6').value = hex2num(document.getElementById('T5').value);";
prog_char htmle4[] PROGMEM = "document.getElementById('T8').value = hex2num(document.getElementById('T7').value);";
prog_char htmle5[] PROGMEM = "document.getElementById('T10').value = hex2num(document.getElementById('T9').value);";
prog_char htmle6[] PROGMEM = "document.getElementById('T12').value = hex2num(document.getElementById('T11').value);\"";
PROGMEM const char *string_table5[] = {htmle0, htmle1, htmle2, htmle3, htmle4, htmle5, htmle6};
const byte ID = 0x92; //used to identify if valid data in EEPROM the "know" bit,
// if this is written in EEPROM the sketch has ran before
// We use this, so that the very first time you'll run this sketch it will use
// the values written above.
// defining which EEPROM address we are using for what data
void setup()
ShieldSetup (); //Setup the Ethernet shield
server.begin(); //starting the server
void ShieldSetup()
int idcheck = EEPROM.read(0);
if (idcheck != ID){
//ifcheck id is not the value as const byte ID,
//it means this sketch has NOT been used to setup the shield before
//just use the values written in the beginning of the sketch
if (idcheck == ID){
//if id is the same value as const byte ID,
//it means this sketch has been used to setup the shield.
//So we will read the values out of EERPOM ans use them
//to setup the shield.
for (int i = 0; i < 6; i++){
mac[i] = EEPROM.read(i+1);
for (int i = 0; i < 4; i++){
ip[i] = EEPROM.read(i+7);
subnet[i] = EEPROM.read(i+11);
gateway[i] = EEPROM.read(i+15);
Ethernet.begin(mac, ip, gateway, subnet);
void loop()
EthernetClient client = server.available();
if (client) {
TextFinder finder(client );
while (client.connected()) {
if (client.available()) {
//This part does all the text searching
if( finder.find("GET /") ) {
// if you find the word "setup" continue looking for more
// if you don't find that word, stop looking and go further
// This way you can put your own webpage later on in the sketch
if (finder.findUntil("setup", "\n\r")){
// if you find the word "SBM" continue looking for more
// it means the SUBMIT button hasn't been pressed an nothing has
// been submitted. Just go to the place where the setup page is
// been build and show it in the client's browser.
if (finder.findUntil("SBM", "\n\r")){
byte SET = finder.getValue();
// Now while you are looking for the letters "DT", you'll have to remember
// every number behind "DT" and put them in "val" and while doing so, check
// for the according values and put those in mac, ip, subnet and gateway.
while(finder.findUntil("DT", "\n\r")){
int val = finder.getValue();
// if val from "DT" is between 1 and 6 the according value must be a MAC value.
if(val >= 1 && val <= 6) {
mac[val - 1] = finder.getValue();
// if val from "DT" is between 7 and 10 the according value must be a IP value.
if(val >= 7 && val <= 10) {
ip[val - 7] = finder.getValue();
// if val from "DT" is between 11 and 14 the according value must be a MASK value.
if(val >= 11 && val <= 14) {
subnet[val - 11] = finder.getValue();
// if val from "DT" is between 15 and 18 the according value must be a GW value.
if(val >= 15 && val <= 18) {
gateway[val - 15] = finder.getValue();
// Now that we got all the data, we can save it to EEPROM
for (int i = 0 ; i < 6; i++){
EEPROM.write(i + 1,mac[i]);
for (int i = 0 ; i < 4; i++){
EEPROM.write(i + 7, ip[i]);
EEPROM.write(i + 11, subnet[i]);
EEPROM.write(i + 15, gateway[i]);
// set ID to the known bit, so when you reset the Arduino is will use the EEPROM values
EEPROM.write(0, 0x92);
// if al the data has been written to EEPROM we should reset the arduino
// for now you'll have to use the hardware reset button
// and from this point on, we can start building our setup page
// and show it in the client's browser.
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
strcpy_P(buffer, (char*)pgm_read_word(&(string_table0[i])));
client.print( buffer );
for (int i = 0; i < 3; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[i])));
client.print(mac[0],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[3])));
client.print(mac[1],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[4])));
client.print(mac[2],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[5])));
client.print(mac[3],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[6])));
client.print(mac[4],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[7])));
client.print(mac[5],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[i])));
client.print(ip[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[4])));
client.print(ip[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[5])));
client.print(ip[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[6])));
client.print(ip[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[0])));
client.print(subnet[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[1])));
client.print(subnet[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[2])));
client.print(subnet[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[3])));
client.print(subnet[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[0])));
client.print(gateway[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[1])));
client.print(gateway[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[2])));
client.print(gateway[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[3])));
client.print(gateway[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[4])));
for (int i = 0; i < 7; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table5[i])));
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[5])));
break;
client.println();
// put your own html from here on
client.print("IT WORKS: go to ");
for (int i= 1; i < 4; i++){
client.print(".");
client.print(ip[i],DEC);
client.print("/setup");
// put your own html until here
break;
delay(1);
client.stop();
