* Fan Controller *
* This program is free software: you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation, either version 3 of the License, or *
* (at your option) any later version. *
* This program is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU General Public License for more details. *
* You should have received a copy of the GNU General Public License *
* along with this program. If not, see <https://www.gnu.org/licenses/>. *
* Date : Friday, 21 January 2011 *
* Author : C.V.Niras/VU3CNS *
* Copyright : (C) 2010 C. V. Niras *
* Email : cvniras@gmail.com *
* Processor : 12F675 *
* First Release : 23/01/2011 *
* Ver : 0.7 *
* Change History: *
* Rev Date Description *
* 0.5 06/03/2011 First stable release *
* 0.6 08/03/2011 Bug fixed - Can't swich on by CH+, when turned *
* off by set speed to 0 *
* 0.7 14/06/2011 Trigger off delayed for full speed (low firing *
* angle) to reach the TRIAC latch current *
#include <pic.h>
#include "type_def.h"
#include "remote_commands.h"
#if defined _12F675
__CONFIG(WDTDIS & MCLRDIS & INTIO & BORDIS & UNPROTECT & PWRTEN);
#define IsIRDataBitHigh() GPIO3 == 0 // Inverted logic
#define SW_UP _GPIO,0 // Up switch
#define SW_DN _GPIO,2 // Down switch
#define LEDOn() GPIO1 = 1 // LED
#define LEDOff() GPIO1 = 0
#define TriacOn() GPIO5 = 0 // Triac
#define TriacOff() GPIObits.GPIO5 = 1
#define TRIAC GPIO5 // Triac pin
#endif
#if defined _16F676
__CONFIG(WDTDIS & MCLRDIS & INTOSCIO & BORDIS & UNPROTECT & PWRTEN);
#define GPIO PORTA
#define TRISIO TRISA
#define GPIF RAIF
#define GPIE RAIE
#define IsIRDataBitHigh() PORTAbits.RA3 == 0 // Inverted logic
#define SW_UP _PORTA,0 // Up switch
#define SW_DN _PORTA,2 // Down switch
#define LEDOn() PORTAbits.RA1 = 1 // LED
#define LEDOff() PORTAbits.RA1 = 0
#define TriacOn() PORTAbits.RA5 = 0 // Triac
#define TriacOff() PORTAbits.RA5 = 1
#define TRIAC PORTAbits.RA5 // Triac pin
// v Added to handle triac2
#define Triac2On() PORTCbits.RC5 = 0 // Triac2
#define Triac2Off() PORTCbits.RC5 = 1
#define TRIAC2 PORTCbits.RC5
// ^ Added to handle triac2
#endif
__EEPROM_DATA(5, 1, 1, 255, 255, 255, 255, 255);
__IDLOC7('0','.','7','B');
#define TIMER_ENABLE // Enable timer
// -- Chip Configurations --
#define _XTAL_FREQ 4000000
#define ZC_PIN_MASK 0x10 // Pin used for zero cross detection
#define IR_PIN_MASK 0x08 // IR sensor output
#define TIME_COUNT 6866 // Number of Timer1 overflows in an hour
#define ANY_KEY Key & 0x80
#define UP_KEY Key & 0x01
#define DN_KEY Key & 0x02
// Timer 1 is the time base, 1 bit time = 8us; the NEC physical bit time is 560us = 70 Timer 1
// The following time are set with a +/- 20% tolerance
#define IR_MARK_MIN_TIME 787
#define IR_SPACE_MIN_TIME 219
#define MIN_IR_BIT_TIME 56
#define MAX_IR_BIT_TIME 84
// -- End of Chip Configurations --
#define IRRx Flag.b0 // New IR bit received
#define IRNewHit Flag.b1 // A new IR command received
#define Error Flag.b2 // General error flag
#define IRCmdRepeat Flag.b3 // A IR repeat command received
#define StartFan Flag.b4 // Indicate to start the fan
#define EEPromWrite Flag.b5 // Indicate to write to EEPROM
#define UnknownCmd Flag.b6 // Unused IR command
#define EETimeUpdate Flag1.b0 // Indicate to update time in eeprom
#define IR05Seconds Flag1.b1 // A 0.5 seconds of IR inactivity, used to clear IR command repeate flag
#define ClearLED Flag1.b2 // Need to turn off LED
#define FanOn Status.b0 // Fan Running
#define TimerRunning Status.b1 // Timer Running
#define AddZeroToIRData() IRData._dword >>= 1 // Add a 0 bit to IR data
#define AddOneToIRData() IRData._dword >>= 1; IRData._dword |= 0x80000000 // Add a 1 bit to IR data
// NEC IR protocol states
typedef enum _NEC_STATES
IR_IDLE,
IR_MARK,
IR_SPACE,
IR_HIGH,
IR_LOW,
IR_REPEAT
} NEC_STATES;
// V A R I A B L E S
//const unsigned char STable[10] = {0, 157, 165, 173, 181, 188, 195, 205, 216, 252};
// Modified to latch low power (load) fans low firing angle (on full speed)
const unsigned char STable[10] = {0, 157, 165, 173, 181, 188, 195, 205, 216, 234};
near volatile BYTE Flag, Flag1, Status;
near NEC_STATES IRState;
unsigned char IRDataCount, PhaseAngle, Speed, Time, Count;
volatile near unsigned char EECounter, Ticks, Key, KeyCount;
volatile unsigned int IRTime, TimeCounter;
DWORD IRData;
// F U N C T I O N P R O T O T Y P E S
void IRHandler(void);
void NECDecoder(void);
void InitIR(void);
void SetSpeed(void);
void OffTimer(void);
void OnTimer(void);
void SetTimer(void);
void GetEEVariables(void);
void SetEEVariables(void);
void KeyDelay(void);
void interrupt isr(void);
void Delay2s(void);
// M A I N
void main(void)
#asm
call 0x3ff
bsf STATUS, 5
movwf OSCCAL & 0x7f
bcf STATUS, 5
#endasm
GPIO = 0; // Clear PORT
PORTC = 0;
TriacOff(); // Triac off
TRISIO = ZC_PIN_MASK | IR_PIN_MASK | 0x05; // IR, Zero cross and swiches
TRISC = 0;
WPU = 0x05; // Weak pull up enabled for wwitches
IOC = ZC_PIN_MASK | IR_PIN_MASK; // Interrupt on change is enabled for GPIO2, GPIO4
ANSEL = 0x00; // All are digital i/o
CMCON = 0x07; // Comparators off
INTCON = 0x68; // Enable PEIE, Timer0, Port change interrupts
OPTION_REG = 0x05; // INT falling edge, Prescaler 1:64
T1CON = 0x31; // Prescaler 1:8, internal clk, TMR1ON
LEDOn();
Flag._byte = 0; // Initialise flags and variables
Flag1._byte = 0;
InitIR();
GetEEVariables(); // Read variables eeprom
IRState = IR_IDLE; // Init IR state
if(FanOn)
StartFan = 1;
FanOn = 0; // This created a fresh start
#ifdef TIMER_ENABLE
if(TimerRunning) // If already started, set the time again
SetTimer();
#endif
GIE = 1; // Enable interrupts
SetSpeed(); // Set the speed
LEDOff(); // Turn off LED
Count = Time << 1; // Count = Time * 2, i.e turn on/off
Ticks = 0;
do
NECDecoder(); // Decode NEC formatted IR data
if(IRNewHit) // Is any new data?
IRNewHit = 0; // Y. Clear flag
IRHandler(); // Do the command
if(IRCmdRepeat) // As long as the repeat command present
{ // do not turn of LED
IRCmdRepeat = 0;
Ticks = 0; // for the same clear Ticks
if(EEPromWrite)
EEPromWrite = 0; // Clear eeprom update flag
SetEEVariables(); // Write variables if necessory
if(ClearLED)
if(Ticks & 0x20) // If remote command received, turn off LED after only
{ // few ms (~320ms)
ClearLED = 0;
LEDOff();
#ifdef TIMER_ENABLE
else if(TimerRunning && (Ticks & 0x40)) // If timer is running and a short time expired (640ms)
{ // used to blink LED to show the time remaining
if(Count == 0xF7) // Reload counter to show the time, after a certain time gap
LEDOff(); // Ensure LED is off
if(!(--Count & 0x80)) // Blinks the LED till counter become -ve
if(Count & 0x01) { // On odd numbers in counter LED on
LEDOn();
if(!(Count & 0x01)) { // For even numbers LED off
LEDOff();
Ticks = 0; // Reset ticks
}//if(TimerRunning && (Ticks & 0x40))
#endif
if(KeyCount >= 4) // Has key pressed for a short time?
if(UP_KEY) // Y. Check for Up key press
StartFan = 1; // Y. Up key pressed, inc the speed
Speed++;
if(DN_KEY) // Check for a down key press
StartFan = 1; // Y. Down key pressed, decrement the speed
Speed--;
if(StartFan) // If any key pressed, do the action
SetSpeed();
KeyDelay(); // Give a delay beore the next check
}while(1);
}// main
// F U N C T I O N S
The function is used to decode IR commands and make changes required
if(!(IRData.byte0 ^ IRData.byte1) == 0) // Address and its compliment match
if(IRData.byte0 == 0) // Address is zero
if(!(IRData.byte2 ^ IRData.byte3) == 0) // Command and its compliment match
UnknownCmd = 0;
switch(IRData.byte2)
case VOL_PLUS:
StartFan = 1;
Speed++;
break;
case VOL_MINUS:
StartFan = 1;
Speed--;
break;
case DIGIT0:
Speed = 0;
OffTimer();
break;
case DIGIT1:
StartFan = 1;
Speed = 1;
break;
case DIGIT2:
StartFan = 1;
Speed = 2;
break;
case DIGIT3:
StartFan = 1;
Speed = 3;
break;
case DIGIT4:
StartFan = 1;
Speed = 4;
break;
case DIGIT5:
StartFan = 1;
Speed = 5;
break;
case DIGIT6:
StartFan = 1;
Speed = 6;
break;
case DIGIT7:
StartFan = 1;
Speed = 7;
break;
case DIGIT8:
StartFan = 1;
Speed = 8;
break;
case DIGIT9:
StartFan = 1;
Speed = 9;
break;
case CH_MINUS:
FanOn = 0;
OffTimer();
break;
case CH_PLUS:
if(Speed == 0) Speed++;
StartFan = 1;
break;
case PREV:
if(FanOn) Time--;
SetTimer();
break;
case NEXT:
if(FanOn) Time++;
SetTimer();
break;
case EQ:
OffTimer();
break;
case PLAY:
OnTimer();
break;
case CH100:
Triac2On();
break;
case CH200:
Triac2Off();
break;
default:
UnknownCmd = 1;
break;
if(!UnknownCmd){
LEDOn(); // A new command received
ClearLED = 1; // Clear LED after a little time
Ticks = 0; // Reset timer ticks
SetSpeed();
}// if((IRData.byte0 ^ IRData.byte1) == 0)
}// if(IRData.byte3 == 0)
}//if((IRData.byte3 ^ IRData.byte2) == 0)
Off the timer, without changing previous set time
void OffTimer(void)
TimerRunning = 0; // Turn off timer
Time = eeprom_read(1); // Read the eeprom, value
EETimeUpdate = 1; // Update time in the eeprom
EECounter = 0; // Clear the eeprom counter to update eeprom
On timer, start with the previous set time, if the timer is not running
void OnTimer(void)
if(FanOn == 1) // Only start Timer when fan on
if(!TimerRunning) // Nothing to do if already started
TimerRunning = 1; // Start the timer
Time = eeprom_read(1); // Get time eeprom
if(Time == 0) // If zero, switch on timer with a non zero value, i.e one hour
Time++;
TimeCounter = TIME_COUNT; // Reload the counter
Set the counters for the timer. When the counter reached zero, the fan will be turned off
If the timer not running, it reload time value with the last saved value the eeprom,
otherwise adjust counters as required, and clear eeprom counter to update time value in the
eeprom, for the same it set a EETimeUpdate flag
void SetTimer(void)
if(Time & 0x80) // A neg, so clear it
Time = 0;
if(Time > 8)
Time = 8; // Max 8 hours
if(FanOn == 0) // Nothing to do if fan is not running
return;
if(!TimerRunning && (Time != 0)) { // If decrementing, and time reached zero, on further
Time = eeprom_read(1); // decrements never start the timer, only start on
TimerRunning = 1; // increments, i.e when time not zero.
if(Time == 0) // If zero, start with a non zero value
Time++; // i.e. set to one
if(Time == 0) // Stop timer, if time is zero
TimerRunning = 0;
Set the speed and update phase angle for a given speed. If start fan flag is set, and fan not running
it starts fan will full speed for a second, then changes to ed speed.
void SetSpeed(void)
if(Speed & 0x80) // A neg, keep it as zero
Speed = 0;
if(Speed >= 10) // Reach the max.
Speed = 9;
if(Speed == 0){
StartFan = 0; // For a zero speed, switch off
FanOn = 0;
if(StartFan){ // If required, try to start the fan
if(!FanOn){ // Already running?
FanOn = 1; // No. Switch on fan
PhaseAngle = STable[9]; // If just swiched on run it on full speed
Delay2s(); // for a short time
StartFan = 0; // Clear the flag
if(FanOn == 0) OffTimer();
PhaseAngle = STable[Speed]; // Set the phase angle for the speed
EECounter = 0; // Update EEPROM
Decode the IR data received in NEC format
static unsigned int IRBitTime, PrevIRTimer;
#if 0
static unsigned char Port;
if((Port ^ GPIO) & IR_PIN_MASK) // IR line changed
*((unsigned char*)&IRTime) = TMR1L; // Copy the current Timer 1 value (LSB)
*((unsigned char*)&IRTime + 1) = TMR1H; // -- do -- (MSB)
Port = GPIO;
IRBitTime = IRTime - PrevIRTimer;
PrevIRTimer = IRTime;
if(IRBitTime & 0x0800)
IRState = IR_IDLE; // Idle for more than 16 ms
IRRx = 0;
#else
if(IRRx)
IRRx = 0;
#endif
Error = 0;
switch(IRState)
case IR_IDLE:
if(IsIRDataBitHigh()) // If it is a one, IR starting
IRState++; // Now is IR_MARK
IRDataCount = 0;
IRData._dword = 0;
break;
case IR_MARK: // Now IR Mark just over
if(IRBitTime < IR_MARK_MIN_TIME)
Error = 1; // Less than specified mark time
IRState++;
break;
case IR_SPACE: // Now IR space just over
if(IRBitTime < IR_SPACE_MIN_TIME)
Error = 1; // Less than specified space time
if(IRBitTime < IR_SPACE_MIN_TIME * 2)
IRState = IR_REPEAT; // If it is less than 4.5 ms, it may be a repeat command
break;
IRState++; // Space is 4.5 ms, now IR high
break;
case IR_HIGH: // IR high just over, check it
if(((unsigned char) IRBitTime < MIN_IR_BIT_TIME) || ((unsigned char) IRBitTime > MAX_IR_BIT_TIME))
Error = 1; // Too short or too long pulse
IRState++;
break;
case IR_LOW: // IR low just over, check it
if(((unsigned char) IRBitTime < MIN_IR_BIT_TIME) || ((unsigned char) IRBitTime > MAX_IR_BIT_TIME * 3))
if((unsigned char) IRBitTime >= MIN_IR_BIT_TIME * 3)
AddOneToIRData(); // Longer low time, add a one
else
AddZeroToIRData(); // Short low time add a zero
IRDataCount++; // Increment the counter
IRState--; // Now is IR High
break;
case IR_REPEAT: // In repeat, the 560us IR burst just over, check it now
IRCmdRepeat = 0;
Error = 1;
IRCmdRepeat = 1;
IRState = IR_IDLE;
break;
}// switch(IRState)
if(Error)
InitIR();
if(IRDataCount == 32)
IRNewHit = 1;
IRState = IR_IDLE;
IRDataCount = 0;
//IROff = 0;
IR05Seconds = 0;
}// if(IRRx)
Initialise IR states
void InitIR( void ) // initial IR engine
IRState = IR_IDLE;
IRNewHit = 0;
IRCmdRepeat = 0;
IRDataCount = 0;
Speed = eeprom_read(0);
Status._byte = eeprom_read(2);
Write to eeprom, the variables
// Compare with the eeprom variables and update if necessory
if(Speed != eeprom_read(0))
eeprom_write(0, Speed);
if(EETimeUpdate) // Time may change while running, so only update
{ // if user make changes
if(Time != eeprom_read(1))
eeprom_write(1, Time);
EETimeUpdate = 0;
if(Status._byte != eeprom_read(2))
eeprom_write(2, Status._byte);
Create a 2 seconds delay, used to start the fan
void Delay2s(void)
unsigned char Count;
Count = 200; // Make a 200 x 10 ms delay
while(--Count != 0)
__delay_ms(10);
Delay after a key press. This function retuns after a specified time or when no key pressed down
void KeyDelay(void)
unsigned char ms;
ms = 250; // 500 ms delay
do
if(!ANY_KEY) // If key released, return
break;
__delay_ms(2);
}while(--ms != 0);
static unsigned char PortStatus, PortChanges;
if(GPIF)
PortChanges = PortStatus; // Copy the previous value
PortStatus = GPIO; // Update PortStatus
GPIF = 0; // Clear interrrupt
PortChanges ^= PortStatus; // Find the differences
if(PortChanges & ZC_PIN_MASK) // Zero cross
TMR0 = PhaseAngle; // Phase angle is controlled via TMR0, on interrupt it trigger
if(FanOn && (PhaseAngle >= STable[9])){ // For full speed hold trigger now, and TMR0 interrupt (delayed
TriacOn(); // to reach TRIAC holding current) clear the trigger
Ticks++; // Ticks @ 10 ms
#asm
INCFSZ _KeyCount,W // Inc Key Count, but not beyond 255
MOVWF _KeyCount
CLRW // Clear W
BTFSS SW_UP // Up Key pressed?
MOVLW 0x81 // Y. Load W with 0x81
BTFSS SW_DN // Down Key pressed?
MOVLW 0x82 // Y. Load W with 0x82
MOVWF _Key // Save W to Key
BTFSS _Key,7 // Has any key pressed?
CLRF _KeyCount // N. Clear the counter
#endasm
}//if(PortChanges & ZC_PIN_MASK)
if(PortChanges & IR_PIN_MASK) // IR line changed
IRRx = 1;
if(T0IF) // Interrupt depends on phase angle (TMR0 is set by phase angle)
if(FanOn){
TriacOn(); // Triac triggered
T0IF = 0; // Clear flag
NOP();
NOP();
NOP();
NOP();
TriacOff(); // Triac off, beacuse already triggered
}//if(T0IF)
if(TMR1IF) // @ 524ms; This interrupt is not set, but polled
{ // with other interrupts
TMR1IF = 0;
#ifdef TIMER_ENABLE
if(TimerRunning && (--TimeCounter == 0)) // If timer running, decrement counter
TimeCounter = TIME_COUNT; // Reload counter
if(--Time == 0) // The time expired, switch off fan and counter
OffTimer(); // Switch off timer
FanOn = 0;
#endif
#asm
INCFSZ _EECounter,W // Inc eeprom timer, but not beyond 255
MOVWF _EECounter
#endasm
if(EECounter == 8) // After 4 seconds since clearing the counter
EEPromWrite = 1; // set eeprom write flag
if(IR05Seconds) // After 0.5 seconds of inactivity
IRCmdRepeat = 0; // clear the repeat command
IR05Seconds = 1;
}//if(TMR1IF)
