Apróhirdetés » Eladó mikroszkóp halogén izzó OSRAM 64255 20 W 8 V
Hirdető: pocok89, idő: 14:14, Hirdető értékelése: Még nincs
Eladók a címben említett új bontatlan csomagolású izzók.
8db van belőle.
Product features and benefits
Precise filament alignment with patented quartz pinch technology
OSRAM HLX lamps provide 10% higher luminous efficacy over standard halogen
Instant on and nearly constant luminous flux over the life of the lamp
Dimmable
Areas of application
Microscopy
Laboratory & Analysis
UV Curing
Fiber Illumination
Surgical & Dental Overhead
Safety advice
To prevent personal injury or damage to property, halogen lamps may only be operated in suitable luminaires designed with suitable mechanisms (protective shields, grids, etc.) to ensure that in the event of a lamp bursting no parts/shards can escape and that during operation no ultraviolet radiation can escape. There must also be a warning sign to indicate that the lamps give off high levels of heat. Detailed information is available on request.
Termék állapota: Új állapotú
Megye: Baranya megye
Település / kerület: Mohács
9 000 Ft
Lejárat: Ápr 3, 2025
Megtekintve: 34
