Szerintem igazad van. Egyszer már kitárgyaltuk a kérdést mágneskapcsolókra vonatkozóan, de szerintem ugyanez igaz szelepekre is. Röviden: Az AC és DC között nem csak a tekercs menetszámában és huzalvastagságban van különbség, hanem konstrukcióban (maga a vasmag is más lehet, tartalmazva a rövidrezárt menetet, többek között) is.
Idézet: „The working power of the AC relay is AC, and the working power of the DC relay is DC. The coil diameter of the AC relay is thicker and the number of turns is less, and the coil diameter of the DC relay has more turns than the thin wire diameter. The core of the AC relay has a short-circuit ring, and the DC does not. The cores of AC relays are mostly E-shaped, and the DC cores are cylindrical. The AC coil will generate heat due to eddy current and hysteresis loss in the iron core, so the coil has a skeleton to isolate the iron core from the coil, and the coil is made into a short and thick chunky type to dissipate heat from the coil and the iron core. Most of the DC coils are thin and tall without a skeleton, so that the coil and the iron core are in direct contact with each other to facilitate heat dissipation. As far as the heating of the coil and the iron core is concerned, in the AC electromagnetic system, the iron core is a heating component, and there is a large gap between the coil and the coil, so as not to transmit heat to the coil, and the shape of the coil is short and thick, which is convenient for the iron core to dissipate heat; DC electromagnetic In the system, the coil is a heating component, there is no gap between it and the iron core, the iron core is used for heat dissipation, and the coil shape is slender, which is convenient for the coil itself to dissipate heat.” Most csak ezt találtam, de talán pont elég. Ha szerintem csak egy darab kell, és nincs bontott, akkor dugasztápot neki...
Kösz mindkettőtöknek. Ezek alapján én le fogom beszélni az áttekercselésről. A dugasztápot én is javasoltam neki, de zavarja a 40 Watt fogyasztás. Persze alig hiszem, hogy AC-sítve kevesebb lehetne, mert mechanikai okokból DC-n sem véletlenül ilyen bika...
40W az nagyon sok. Nem tudom, mennyi ideig van behúzva, de ha sokat, ezt biztosan lecserélném valami másra, amint lehet.
Ez a 3A-es áramfelvétel mért érték?
Nagyon soknak tűnik! A szelep működtetéséhez biztosan nincs szükség ekkora energiára. Az a 36W szerintem akkora hőt termelne, ami gyorsan szénné égeti azt a tekercset ... Én inkább 3-5W-os fogyasztást tartanák reálisnak!
Igen, a mért érték valójában 3,2 A volt, de ez teljesen klappol a 4 ohmos ellenállással. Ezt a szelepet valószínűleg nem arra szánták, hogy állandóan nyitva legyen (mert alapból zárt állapotban van), hanem rövid idejű nyitásokra. Mivel specifikáció szerint meglehetősen nagy nyomásra van tervezve, mechanikailag is erősnek kell lennie. Természetesen így nem használható arra a célra, amire a szomszéd használni akarta (áramszünet esetén zárjon).
Közben meglett a megoldás: mivel nála nem nagy nyomású körben lesz, ezért kipróbáltuk úgy, hogy kivette belőle a meglehetősen erős rugót. A szerelt pozícióban a vasmag gravitációs ereje fogja zárni a szelepet. Így 5V-ról szépen nyit/zár, és az Ohm törvényt is betartva kb. 6W disszipációval meg lehet úszni ![]() Idézet: „A szerelt pozícióban a vasmag gravitációs ereje fogja zárni a szelepet.” Inkább a föld gravitációs ereje. ![]()
Igazad van, nem a vasmag ereje, hanem a súlya fog zárni. A konstrukció szerencsére olyan, hogy zárt állapotban a membrán mögötti nyomás besegít, úgyhogy ezzel vsz. nem lesz gond.
A gyengébb rugó ötlete nálunk is felmerült; nyomás nélkül ki is mértem, hogy mekkora feszültséggel lehet működtetni az eredeti / gyengébb rugóval, ill. rugó nélkül. Persze nyomás alatt más lesz a helyzet...
Üdv a tisztelt fórumozóknak! Ez a kijelző jelenség javítható, vagy sem? Nem ázott be, egyszer csak ilyen lett. LG tablet
De beázott ezek szerint.
Aránylag ritkán használok tabletet búvárkodás vagy zuhanyozás közben, és gondolom lenne a beázásnak nyoma az alaplapon is . Az pedig teljesen tiszta! Állandóan a laptop táskában tartom, ha kellene, ebben ugyan is van SIM kártya... és a laptop táska sem ázott el
Irfz44n fetekkel szeretnék diesel motor izzítógyertyákat be ki kapcsolni. A problémát az jelenti hogy az izzító gyertya mindenképp az alsó tagba kell kerüljön mivel 1 kivezetése van a másik maga a test. Megoldható a feladat?
PNP fettel igen. NPN-nel nem, mert nem tudsz pozitívabb vezérlést biztosítani, mint a 12V.
Tudnál javasolni egy típust esetleg?
Azt nm, de érdemes a lehető, (gazdaságosan), legnagyobb áramút választani, mert elég komoly árammal indul. Sőt! Külön gyertyánként.
Elég elterjedt típus az IRF4905 és paraméterekben is megfelel a célra.
Megoldható P és N fettel is, csak az utóbbival kicsit bonyolultabb, viszont N fetből nagyobb a választék. Maximálisan mekkora áram folyik az izzítógyertyán? Ehhez az áramhoz kell méretezni a FET-et, és azt is el kell dönteni, hogy hűtőbordára szereled-e a FET-et vagy hűtés nélkül szeretnéd megoldani (ez utóbbi esetben jobban túl kell méretezni a FET-et, és esetleg több darabra lesz szükség). A korábban említett IRF4905 egy elég jó FET, de saccra ebből eleve több darab kell párhuzamosan, hogy a melegedése kezelhető mértékű maradjon. 20mΩ vezetési ellenállása van (hidegen, melegen kb. a duplája) ennélfogva hűtés nélkül max 5A-re érdemes használni (0,5...1W), hűtőbordán pedig olyan 10...20A-ig (2...16W). Azt is figyelembe kell venni, hogy ha közös hűtőbordán van több darab, akkor egymást is melegítik... Tehát mégegyszer: Maximálisan mekkora áram folyhat az izzítógyertyán?
A hozzászólás módosítva: Júl 28, 2023
Netről olvasva 10 A, tipus nélkül és gondolom nem hidegen (-20).
Durván túl kell méretezni a FET-et szerintem. Mivel az izzító gyertya testje fix, ezért csak szigetelten lehet szerelni a FET-et...
lemerült 13400-as akksi töltésében kérném a segítségetek. Van nekem itthon egy szétszedett powerbank aminek a töltőelektronikáját szeretném segítségül hívni erre a feladatra. A powerbank akksijának feszültségét megmértem, 3,7V-ot mutatott a multiméter(nincs teljesen feltöltött állapotban). Elvileg van ezen az elektronikán töltésjelző is. A powerbank akksija egy kék jelöletlen valami, arról egyéb információt nem tudok. Van rá esély, hogy ezzel az elektronikával biztonságosan tölthetem a 13400-as akksit? Előre is köszönöm válaszotok! Üdv, Arnold
Üdv, az a gond, hogy ez az elektronika szerintem (de látni kellene az IC adatlapját, vagy megmérni),
1-2A -al tölti a rácsatlakoztatott cellát. Na ezt a nagy áramot az az 500mAh-s cella nem nagyon fogja szeretni. Ha van legalább három, de inkább négy ilyen 500-as cellád, és párhuzamosan ráteszed mindet, akkor jó lehet. A hozzászólás módosítva: Júl 29, 2023
Közben megmértem az áramerősséget az eredeti akksi töltése közben és igen, sajnos kb 950mA-al tölti, szóval ez sok lesz neki. :/ Még van 1 db ilyen akksim, de gondolom még az 500 mA is sok lenne neki ha párhuzamosan tölteném.
Lehet, hogy buta kérdés de az nem lehetséges, hogy az elektronikában van valami védelmi funkció és ha érzékeli hogy keveset kell tölteni akkor alacsonyabb áramerősséggel teszi? Arra gondoltam, hogy rákötöm a 13400as akksira és nézem, hogy mekkora az áramerősség, gondolom pár másodperc alatt nem tudok kárt tenni a kis akksiban (és magamban).
Ha van kettő, párhuzamosítsd, 1A-t ki fog bírni, de ne hagyd magára. Ha kezd melegedni, szüneteltesd a töltést, várd meg míg visszahűl, és utána folytathatod. Ha nem melegszik 40°C (erős langyos) fölé,
akkor mehet folyamatosan is. Töltés vége felé természetesen csökken az áramerősség, mert utána már feszültséggenerátoros módba vált. Az első szakasz áramgenerátoros, amíg el nem éri a 4.2V -ot. Egyébként meg vegyél hozzá egy kisebb áramú 18650-es töltőt. Pl TP4051 és a programozó ellenállással állítsd át 300-500mA -es üzemmódra. A hozzászólás módosítva: Júl 29, 2023
Legjobban akkor jársz ha veszel pl tp4056 vagy tp5100 toltő modulocskát. (Gondolom RégiMotoros is erre célzott). Ezek a modulok tudják, amit kell
![]() Itt a Hestoreban is kapható... Ha mindenáron mahinálni akarsz, akkor labortáp áram korlát 30mA-ra, és ha elérte a 3V töltöttséget, feljebb veheted a töltőáramot...
Ja igen, azt. Félreírtam.
Régi motoros, pipi,
Köszönöm szépen a hasznos információkat! ![]() Lehet, hogy megpróbálom holnap azt a megoldást, hogy figyelem a hőmérsékletét, viszont majd amint tudok veszek hozzá egyet a fent említett töltőmodulokból.
Lehet teljesen láma kérdés de lehet 400 Voltos kapcsolóval 230 Voltot is kapcsolni? Például ezzel?
Igen, lehet. A 400 V a maximálisan kapcsolható feszültség, minimális lehet akár 0.1 V is.
Egy raktárba szeretnék telepíteni 20db andon lámpát. Az 5 színből maximum csak 1db lesz használva egyszerre. (12V 4W) Raspberry PI 4 adná a soros jelet, amit HC595 segítségével párhuzamos jellé alakítanék. Kicsiben, 2mA-es LED-ekkel ezt már megcsináltam próbapanelen. (A programozás része nem okoz gondot) A kérdésem az volna, hogy mit javasoltok a nagyobb áramfelvételű fényforrások táplálására? ULN2003-ban gondolkodtam, amely lábairól egyszerre le lehet venni 500mA-t. Viszont, itt nagyon kell figyelni, hogy nehogy egyszerre több lámpának adjak jelet, mert akkor ez az IC nem fogja elbírni. (Ugye csak akkor bír el 500mA-t, ha csak egy lábat hajtunk egyszerre max) Gondolkodom, hogy ULN2003 helyett külön MOSFET-ekkel táplálnám a fényforrásokat, de ebben nincs tapasztalatom. Tudnátok segíteni? A stabilitás nagyon fontos, - hosszútávú, 0-24-ben futó rendszert szeretnénk. Köszönöm szépen! Zoli |
