// Project: TinyLoad - Simple Electronic Constant Current Dummy Load (ATtiny45/85)
// Version: v1.2
// Year: 2020 - 2021
// Author: Stefan Wagner
// Github: https://github.com/wagiminator
// Description:
// The ATtiny measures voltage, current and temperature of the heat sink,
// calculates power, energy and electric charge, controls the fan and displays
// all relevant data on the OLED. The button is used to switch between
// power/resistance and energy/charge display.
// References:
// The I²C OLED implementation is based on TinyOLEDdemo
// OLED font was adapted from Neven Boyanov and Stephen Denne
// Wiring:
// Button/NTC --- RST ADC0 PB5 1|° |8 Vcc
// Voltage Sensor ------- ADC3 PB3 2| |7 PB2 ADC1 -------- OLED SCK
// Current Sensor ------- ADC2 PB4 3| |6 PB1 AIN1 OC0B --- Fan Control
// GND 4| |5 PB0 AIN0 OC0A --- OLED SDA
// Compilation Settings:
// Core: ATtinyCore (https://github.com/SpenceKonde/ATTinyCore)
// Board: ATtiny25/45/85 (No bootloader)
// Chip: ATtiny45 or 85 (depending on your chip)
// Clock: 1 MHz (internal)
// B.O.D.: 2.7V
// Leave the rest on default settings. Don't forget to "Burn bootloader"!
// No Arduino core functions or libraries are used. Use the makefile if
// you want to compile without Arduino IDE.
// Note: RESET pin is used as a weak analog input for the set button and the NTC
// thermistor. You don't need to disable the RESET pin as the voltage won't
// go below 40% of Vcc.
// Fuse settings: -U lfuse:w:0x62:m -U hfuse:w:0xd5:m -U efuse:w:0xff:m
// Operating Instructions:
// The ADC of the ATtiny does its best to make the tinyLoad a pretty accurate
// tool, but it might need a little calibration.
// How to calibrate:
// Set ULCAL and ILCAL to "1" in the sketch, compile and upload.
// Choose a stable input voltage of around 5V and turn the poti until the
// display shows a current of around 0.7A. Measure the voltage and the current
// with a trusty multimeter or a good lab bench power supply.
// Calculate the voltage calibration factor as follows:
// ULCAL = voltage measured with multimeter / voltage shown on OLED.
// Calculate the current calibration factor as follows:
// ILCAL = current measured with multimeter / current shown on OLED.
// Set the ULCAL and ILCAL value in the sketch, compile and upload again.
// Notes:
// - Use a good heatsink with a 5V fan for the MOSFET!
// - Be careful with high power loads! This device is called "tinyLoad" for a reason!
// - Always turn the POTI full counter-clockwise before connecting the load!
// - Due to the input offset voltage of the OpAmp the minimum load current is 17mA.
// - The maximum load current is 4.5A, however for small voltages it might be less.
// - Do not exceed the maximum voltage of 26V!
// Libraries, Definitions and Macros
// Libraries
#include <avr/io.h> // for GPIO
#include <avr/sleep.h> // for sleep functions
#include <avr/pgmspace.h> // for data stored in program memory
#include <avr/interrupt.h> // for interrupts
#include <util/delay.h> // for delays
// Pin assignments
#define PIN_SDA PB0 // I2C serial data pin, connected to OLED
#define PIN_SCL PB2 // I2C serial clock pin, connected to OLED
#define PIN_FAN PB1 // pin connected to MOSFET for fan control
#define PIN_VOLTAGE PB3 // pin for voltage measurement
#define PIN_CURRENT PB4 // pin for current measurement
#define PIN_NTC PB5 // pin connected to NTX and button
// Calibration values for internal 1.1V reference
#define ULCAL 1 // linear voltage calibration factor
#define ILCAL 0.921 // linear current calibration factor
// Parameter definitions
#define MAXPOWER 15 // max power in watt
#define UCONV 11486336 // voltage conversion = 1000*64*1023*R11/(R10+R11)
#define ICONV 72019200 // current conversion = 1000*64*1023*R_shunt*(R8+R9)/R9
// RESET pin ADC values (tweak a little, if button/NTC do not work correctly)
#define NTCMIN 550 // lowest ADC value for NTC; below is a button press
#define NTCFAN 625 // turn on the fan if ADC value is below
#define NTCHOT 560 // show warning screen if ADC value is below
// Pin manipulation macros
#define pinInput(x) DDRB &= ~(1<<(x)) // set pin to INPUT
#define pinOutput(x) DDRB |= (1<<(x)) // set pin to OUTPUT
#define pinLow(x) PORTB &= ~(1<<(x)) // set pin to LOW
#define pinHigh(x) PORTB |= (1<<(x)) // set pin to HIGH
#define pinDisable(x) DIDR0 |= (1<<(x)) // disable digital input buffer
#define pinRead(x) (PINB & (1<<(x))) // READ pin
#define pinADC(x) ((x)==2?1:((x)==3?3:((x)==4?2:0))) // convert pin to ADC port
// Pin to ADC port conversion macros
#define AP_NTC pinADC(PIN_NTC) // ADC port of fan pin
#define AP_CURRENT pinADC(PIN_CURRENT) // ADC port of current sense pin
#define AP_VOLTAGE pinADC(PIN_VOLTAGE) // ADC port of voltage sense pin
// I2C Master Implementation (write only)
// I2C macros
#define I2C_SDA_HIGH() pinInput(PIN_SDA) // release SDA -> pulled HIGH by resistor
#define I2C_SDA_LOW() pinOutput(PIN_SDA) // SDA as output -> pulled LOW by MCU
#define I2C_SCL_HIGH() pinInput(PIN_SCL) // release SCL -> pulled HIGH by resistor
#define I2C_SCL_LOW() pinOutput(PIN_SCL) // SCL as output -> pulled LOW by MCU
// I2C transmit one data byte to the slave, ignore ACK bit, no clock stretching allowed
void I2C_write(uint8_t data) {
for(uint8_t i=8; i; i--, data<<=1) { // transmit 8 bits, MSB first
(data&0x80)?I2C_SDA_HIGH():I2C_SDA_LOW(); // SDA depending on bit
I2C_SCL_HIGH(); // clock HIGH -> slave reads the bit
I2C_SCL_LOW(); // clock LOW again
I2C_SDA_HIGH(); // release SDA for ACK bit of slave
I2C_SCL_HIGH(); // 9th clock pulse is for the ACK bit
I2C_SCL_LOW(); // but ACK bit is ignored
// I2C start transmission
void I2C_start(uint8_t addr) {
I2C_SDA_LOW(); // start condition: SDA goes LOW first
I2C_SCL_LOW(); // start condition: SCL goes LOW second
I2C_write(addr); // send slave address
// I2C stop transmission
void I2C_stop(void) {
I2C_SDA_LOW(); // prepare SDA for LOW to HIGH transition
I2C_SCL_HIGH(); // stop condition: SCL goes HIGH first
I2C_SDA_HIGH(); // stop condition: SDA goes HIGH second
// OLED Implementation
// OLED definitions
#define OLED_ADDR 0x78 // OLED write address
#define OLED_CMD_MODE 0x00 // set command mode
#define OLED_DAT_MODE 0x40 // set data mode
#define OLED_INIT_LEN 9 // length of init command array
// Standard ASCII 5x8 font (adapted from Neven Boyanov and Stephen Denne)
const uint8_t OLED_FONT[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2F, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00,
0x14, 0x7F, 0x14, 0x7F, 0x14, 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x23, 0x13, 0x08, 0x64, 0x62,
0x36, 0x49, 0x55, 0x22, 0x50, 0x00, 0x05, 0x03, 0x00, 0x00, 0x00, 0x1C, 0x22, 0x41, 0x00,
0x00, 0x41, 0x22, 0x1C, 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14, 0x08, 0x08, 0x3E, 0x08, 0x08,
0x00, 0x00, 0xA0, 0x60, 0x00, 0x08, 0x08, 0x08, 0x08, 0x08, 0x00, 0x60, 0x60, 0x00, 0x00,
0x20, 0x10, 0x08, 0x04, 0x02, 0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00, 0x42, 0x7F, 0x40, 0x00,
0x42, 0x61, 0x51, 0x49, 0x46, 0x21, 0x41, 0x45, 0x4B, 0x31, 0x18, 0x14, 0x12, 0x7F, 0x10,
0x27, 0x45, 0x45, 0x45, 0x39, 0x3C, 0x4A, 0x49, 0x49, 0x30, 0x01, 0x71, 0x09, 0x05, 0x03,
0x36, 0x49, 0x49, 0x49, 0x36, 0x06, 0x49, 0x49, 0x29, 0x1E, 0x00, 0x36, 0x36, 0x00, 0x00,
0x00, 0x56, 0x36, 0x00, 0x00, 0x08, 0x14, 0x22, 0x41, 0x00, 0x14, 0x14, 0x14, 0x14, 0x14,
0x00, 0x41, 0x22, 0x14, 0x08, 0x02, 0x01, 0x51, 0x09, 0x06, 0x32, 0x49, 0x59, 0x51, 0x3E,
0x7C, 0x12, 0x11, 0x12, 0x7C, 0x7F, 0x49, 0x49, 0x49, 0x36, 0x3E, 0x41, 0x41, 0x41, 0x22,
0x7F, 0x41, 0x41, 0x22, 0x1C, 0x7F, 0x49, 0x49, 0x49, 0x41, 0x7F, 0x09, 0x09, 0x09, 0x01,
0x3E, 0x41, 0x49, 0x49, 0x7A, 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00, 0x41, 0x7F, 0x41, 0x00,
0x20, 0x40, 0x41, 0x3F, 0x01, 0x7F, 0x08, 0x14, 0x22, 0x41, 0x7F, 0x40, 0x40, 0x40, 0x40,
0x7F, 0x02, 0x0C, 0x02, 0x7F, 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x4E, 0x71, 0x01, 0x71, 0x4E,
0x7F, 0x09, 0x09, 0x09, 0x06, 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x7F, 0x09, 0x19, 0x29, 0x46,
0x46, 0x49, 0x49, 0x49, 0x31, 0x01, 0x01, 0x7F, 0x01, 0x01, 0x3F, 0x40, 0x40, 0x40, 0x3F,
0x1F, 0x20, 0x40, 0x20, 0x1F, 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x63, 0x14, 0x08, 0x14, 0x63,
0x07, 0x08, 0x70, 0x08, 0x07, 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, 0x7F, 0x41, 0x41, 0x00,
0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x41, 0x41, 0x7F, 0x00, 0x04, 0x02, 0x01, 0x02, 0x04,
0x40, 0x40, 0x40, 0x40, 0x40, 0x00, 0x01, 0x02, 0x04, 0x00, 0x20, 0x54, 0x54, 0x54, 0x78,
0x7F, 0x48, 0x44, 0x44, 0x38, 0x38, 0x44, 0x44, 0x44, 0x20, 0x38, 0x44, 0x44, 0x48, 0x7F,
0x38, 0x54, 0x54, 0x54, 0x18, 0x08, 0x7E, 0x09, 0x01, 0x02, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,
0x7F, 0x08, 0x04, 0x04, 0x78, 0x00, 0x44, 0x7D, 0x40, 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,
0x7F, 0x10, 0x28, 0x44, 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,
0x7C, 0x08, 0x04, 0x04, 0x78, 0x38, 0x44, 0x44, 0x44, 0x38, 0xFC, 0x24, 0x24, 0x24, 0x18,
0x18, 0x24, 0x24, 0x18, 0xFC, 0x7C, 0x08, 0x04, 0x04, 0x08, 0x48, 0x54, 0x54, 0x54, 0x20,
0x04, 0x3F, 0x44, 0x40, 0x20, 0x3C, 0x40, 0x40, 0x20, 0x7C, 0x1C, 0x20, 0x40, 0x20, 0x1C,
0x3C, 0x40, 0x30, 0x40, 0x3C, 0x44, 0x28, 0x10, 0x28, 0x44, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,
0x44, 0x64, 0x54, 0x4C, 0x44, 0x08, 0x36, 0x41, 0x41, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00,
0x00, 0x41, 0x41, 0x36, 0x08, 0x08, 0x04, 0x08, 0x10, 0x08, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
// OLED init settings
const uint8_t OLED_INIT_CMD[] PROGMEM = {
0xC8, 0xA1, // flip screen
0xA8, 0x1F, // set multiplex ratio
0xDA, 0x02, // set com pins hardware configuration
0x8D, 0x14, // set DC-DC enable
0xAF // display on
// OLED variables
uint8_t OLED_x, OLED_y; // current cursor position
const uint16_t DIVIDER[] PROGMEM = {10000, 1000, 100, 10, 1}; // BCD conversion array
// OLED init function
void OLED_init(void) {
I2C_start(OLED_ADDR); // start transmission to OLED
I2C_write(OLED_CMD_MODE); // set command mode
for(uint8_t i = 0; i < OLED_INIT_LEN; i++)
I2C_write(pgm_read_byte(&OLED_INIT_CMD[i]));// send the command bytes
I2C_stop(); // stop transmission
// OLED set the cursor
void OLED_setCursor(uint8_t xpos, uint8_t ypos) {
I2C_write(xpos & 0x0F); // set low nibble of start column
I2C_write(0x10 | (xpos >> 4)); // set high nibble of start column
I2C_write(0xB0 | (ypos & 0x07)); // set start page
OLED_x = xpos; OLED_y = ypos; // set the cursor variables
// OLED clear line
void OLED_clearLine(uint8_t line) {
OLED_setCursor(0, line); // set cursor to line start
I2C_write(OLED_DAT_MODE); // set data mode
for(uint8_t i=128; i; i--) I2C_write(0x00); // clear the line
// OLED clear screen
void OLED_clearScreen(void) {
for(uint8_t i=0; i<4; i++) // 4 lines
OLED_clearLine(i); // clear line
// OLED plot a single character
void OLED_plotChar(char c) {
uint16_t ptr = c - 32; // character pointer
ptr += ptr << 2; // -> ptr = (ch - 32) * 5;
I2C_write(0x00); // write space between characters
for(uint8_t i=5 ; i; i--) I2C_write(pgm_read_byte(&OLED_FONT[ptr++]));
OLED_x += 6; // update cursor
if(OLED_x > 122) { // line end ?
I2C_stop(); // stop data transmission
OLED_setCursor(0,++OLED_y); // set next line start
// OLED print a string from program memory
void OLED_printPrg(const char* p) {
char ch = pgm_read_byte(p); // read first character from program memory
while(ch) { // repeat until string terminator
OLED_plotChar(ch); // print character on OLED
ch = pgm_read_byte(++p); // read next character
// OLED print 8-bit value as 2-digit decimal (BCD conversion by substraction method)
void OLED_printDec8(uint8_t value) {
uint8_t digitval = 0; // start with digit value 0
while(value >= 10) { // if current divider fits into the value
digitval++; // increase digit value
value -= 10; // decrease value by divider
OLED_plotChar(digitval + '0'); // print first digit
OLED_plotChar(value + '0'); // print second digit
// OLED print 16-bit value as decimal (BCD conversion by substraction method)
void OLED_printDec16(uint16_t value) {
uint8_t leadflag = 0; // becomes "1" on first digit
for(uint8_t digit = 0; digit < 5; digit++) { // 5 digits
uint16_t divider = pgm_read_word(&DIVIDER[digit]); // current divider
while(value >= divider) { // if current divider fits into the value
leadflag = 1; // end of leading spaces
value -= divider; // decrease value by divider
if(leadflag || (digit == 4)) OLED_plotChar(digitval + '0'); // print the digit
else OLED_plotChar(' '); // print leading space
// OLED print float right-aligned
void OLED_printValue(float value) {
value += 0.005; // for rounding
uint16_t front = value; // left side of decimal
uint8_t back = (value - front) * 100 ; // right side of decimal
OLED_printDec16(front); // print left side of decimal
OLED_plotChar('.'); // print decimal
OLED_printDec8(back); // print right side of decimal
I2C_stop(); // stop transmission to OLED
// Millis Counter Implementation for Timer0
volatile uint32_t MIL_counter = 0; // millis counter variable
// Init millis counter
void MIL_init(void) {
OCR0A = 124; // TOP: 124 = 1000kHz / (8 * 1kHz) - 1
TCCR0A = (1<<WGM01); // timer0 CTC mode
TCCR0B = (1<<CS01); // start timer0 with prescaler 8
TIMSK = (1<<OCIE0A); // enable output compare match interrupt
// Read millis counter
uint32_t MIL_read(void) {
cli(); // disable interrupt for atomic read
uint32_t result = MIL_counter; // read millis counter
sei(); // enable interrupts
return result; // return millis counter value
// Timer0 compare match A interrupt service routine (every millisecond)
ISR(TIM0_COMPA_vect) {
MIL_counter++; // increase millis counter
// ADC Implementation
// Voltage references
#define REFVCC 0 // Vcc as reference
#define REF1V1 (1<<REFS1) // internal 1.1V reference
#define REF2V56 ((1<<REFS2) | (1<<REFS1)) // internal 2.56V reference
#define AVBG ((1<<MUX3) | (1<<MUX2)) // port of internal bandgap (1.1V reference)
// ADC init
void ADC_init(void) {
ADCSRA = (1<<ADPS1) | (1<<ADPS0) // set ADC clock prescaler to 8
| (1<<ADEN) // enable ADC
| (1<<ADIE); // enable ADC interrupt
// ADC add up several readings (oversampling) against choosen reference in sleep mode to denoise
// max samples: 64
uint16_t ADC_read(uint8_t port, uint8_t reference, uint8_t samples) {
uint16_t result = 0; // result
ADCSRA |= (1<<ADEN) | (1<<ADIF); // enable ADC, turn off any pending interrupt
ADMUX = (port & 0x0f) | reference; // set input channel and reference
if(reference || (port==AVBG)) _delay_ms(2); // wait 2ms to settle if Vref is used
set_sleep_mode(SLEEP_MODE_ADC); // sleep during sample for noise reduction
for(; samples; samples--) { // get several samples
sleep_mode(); // go to sleep while taking ADC sample
while(ADCSRA & (1<<ADSC)); // make sure sampling is completed
result += ADC; // add them up
return result; // return value
// ADC interrupt service routine
EMPTY_INTERRUPT(ADC_vect); // nothing to be done here
// Additional Functions
// Check if button is pressed
uint8_t buttonPressed(void) {
uint16_t value = ADC_read(AP_NTC, REFVCC, 1);
return(value < NTCMIN);
// Check if NTC is connected
uint8_t NTCpresent(void) {
return( (value >= NTCMIN) && (value < 1020) );
// Main Function
// Text strings stored in program memory
const char StartScreen[] PROGMEM =
"-- TinyLoad v1.2 --"
"Turn poti full CCW, "
"connect the load and "
"press SET button. ";
const char WarnScreen[] PROGMEM =
"!!!!! WARNING !!!!!"
"You reached max power"
" or temperature ! "
"!!! DECREASE LOAD !!!";
// Main function
int main(void) {
// Local variables
uint16_t vcc, vref2, onevolt, twovolt, rawCheck, temp;
float rawVoltage, rawCurrent, voltage, current, power, resistance;
float capacity = 0;
float energy = 0;
uint8_t primescreen = 1;
uint8_t warnscreen;
uint8_t lastbutton;
uint32_t lastmillis, nowmillis, interval;
// Setup
pinOutput(PIN_FAN); // set output pins
pinDisable(PIN_NTC); // disable digital input buffer
pinDisable(PIN_VOLTAGE); // disable digital input buffer
pinDisable(PIN_CURRENT); // disable digital input buffer
MIL_init(); // setup millis counter
ADC_init(); // setup ADC
OLED_init(); // prepare and start OLED
sei(); // enable global interrupts
// Calibrate internal 2.56V reference
vref2 = ADC_read(AVBG, REF2V56, 64); // read internal bandgap against 2.56V reference
vref2 = (uint32_t)72019200 / vref2; // calculate Vref2 in mV; 72019200 = 64*1023*1100
// Check if something is connected to the load
OLED_clearScreen();
OLED_setCursor(0,0);
OLED_printPrg(StartScreen);
while( (!buttonPressed()) && (ADC_read(AP_CURRENT, REF1V1, 1) < 10) );
// Init some variables;
lastmillis = MIL_read();
lastbutton = 1;
// Loop
while(1) {
vcc = ADC_read(AVBG, REFVCC, 64); // read internal bandgap against Vcc with 64 samples
vcc = (uint32_t)72019200 / vcc; // calculate Vcc in mV; 1125300 = 64*1023*1100
onevolt = (uint32_t)1125300 / vcc; // calculate ADC-value for 1.1V
twovolt = (uint32_t)vref2 * 1023 / vcc; // calculate ADC-value for 2.56V (calibrated)
// Read and calculate voltage in V
rawCheck = ADC_read(AP_VOLTAGE, REFVCC, 1); // get ADC-value for voltage reading
if (rawCheck < onevolt) { // check possibility of reading against 1.1V reference
rawVoltage = ADC_read(AP_VOLTAGE, REF1V1, 64); // read raw voltage against 1.1V reference
voltage = rawVoltage * 1100 / UCONV * ULCAL; // calculate real voltage value
else if (rawCheck < twovolt) { // check possibility of reading against 2.56V reference
rawVoltage = ADC_read(AP_VOLTAGE, REF2V56, 64); // read raw voltage against 2.56V reference
voltage = rawVoltage * vref2 / UCONV * ULCAL; // calculate real voltage value
else {
rawVoltage = ADC_read(AP_VOLTAGE, REFVCC, 64); // read raw voltage against vcc
voltage = rawVoltage * vcc / UCONV * ULCAL; // calculate real voltage value
// Read and calculate current in A
rawCheck = ADC_read(AP_CURRENT, REFVCC, 1); // get ADC-value for current reading
if(rawCheck < onevolt) { // check possibility of reading against 1.1V reference
rawCurrent = ADC_read(AP_CURRENT, REF1V1, 64); // read raw current against 1.1V reference
current = rawCurrent * 1100 / ICONV * ILCAL; // calculate real current value
else if(rawCheck < twovolt) { // check possibility of reading against 2.56V reference
rawCurrent = ADC_read(AP_CURRENT, REF2V56, 64); // read raw current against 2.56V reference
current = rawCurrent * vref2 / ICONV * ILCAL; // calculate real current value
else {
rawCurrent = ADC_read(AP_CURRENT, REFVCC, 64); // read raw current against vcc
current = rawCurrent * vcc / ICONV * ILCAL; // calculate real current value
// Calculate power and resistance
power = voltage * current; // calculate power in W
if(current > 0) resistance = voltage / current; // calculate resistance in Ohm
else resistance = 9999; // 9999 if no current
if(resistance > 9999) resistance = 9999; // 9999 is max displayed value
// Calculate energy/capacity in mWh and mAh
nowmillis = MIL_read();
interval = nowmillis - lastmillis; // calculate time interval
lastmillis = nowmillis;
energy += power * interval / 3600; // calculate mWh
capacity += current * interval / 3600; // calculate mAh
// Turn on fan if needed
temp = ADC_read(AP_NTC, REFVCC, 1);
if( (power > 8) || ( (temp >= NTCMIN) && (temp < NTCFAN) ) ) pinHigh(PIN_FAN);
else pinLow(PIN_FAN);
// Check limits
warnscreen = ( (power > MAXPOWER) || ( (temp >= NTCMIN) && (temp < NTCHOT) ) );
// Check button
if (!lastbutton && buttonPressed()) primescreen = !primescreen;
lastbutton = buttonPressed();
// Display values on the oled
if(warnscreen) OLED_printPrg(WarnScreen);
else {
OLED_printPrg(PSTR("Voltage: ")); OLED_printValue(voltage); OLED_printPrg(PSTR(" V"));
OLED_printPrg(PSTR("Current: ")); OLED_printValue(current); OLED_printPrg(PSTR(" A"));
if(primescreen) {
OLED_printPrg(PSTR("Power: ")); OLED_printValue(power); OLED_printPrg(PSTR(" W"));
OLED_printPrg(PSTR("Resistance:")); OLED_printValue(resistance); OLED_printPrg(PSTR(" O"));
else {
OLED_printPrg(PSTR("Energy: ")); OLED_printValue(energy); OLED_printPrg(PSTR(" mWh"));
OLED_printPrg(PSTR("Charge: ")); OLED_printValue(capacity); OLED_printPrg(PSTR(" mAh"));
_delay_ms(50);
